Injector swap question...
With all that said, the SVO will run around 25.2# due to the fact that Ford runs like 38psi for fuel pressure, where as we run 41-43psi. There's calcs online you can punch in to convert from XXXpsi to whatever PSI you run, and it'll tell you the new injector rating. I think with SVO it doesn't scale with how big of injectors you run, it's more of a constant 1.xx# more. So 40# would just be 41.5~#.
