which way do the header gaskets go?
Old Apr 30, 2008 | 02:18 PM
camarostripes96's Avatar
From: Academy,Tx (home of temple/academy Drag Strip)
Default which way do the header gaskets go?
i have the copper header gasket from mr. gasket, and one side is raised and the other side is flat , which way goes towards the head?
Old Apr 30, 2008 | 03:45 PM
caldercay's Avatar
Flat side goes to the head. Most will have some printing on one side, which
would face to the headers.
Old Apr 30, 2008 | 03:58 PM
ok sweet , well i just got the driver side in , how do i get the passenger side header in ?
Old Apr 30, 2008 | 04:00 PM
Nole Chick's Avatar
From the bottom...
ok well its hard, do i need to jack the motor up
Old Apr 30, 2008 | 04:05 PM
Nole Chick's Avatar
How high up is the car? Should be able to get it in and up from underneath if you have the right amount of clearance. Might be a two person job....
Old Apr 30, 2008 | 04:07 PM
caldercay's Avatar
I removed the motor mount through-bolt on the passenger side, jacked the engine
up about an inch, and the headers slid up from underneath (with a bit of a twist).
Old Apr 30, 2008 | 04:39 PM
SiDeWaYZz28's Avatar
pray that those gaskets seal.Ive had nothing but headaches with copper gaskets
Old May 1, 2008 | 12:06 AM
got em done!! Header install complete...not that bad after all
Old May 1, 2008 | 05:25 PM
Nole Chick's Avatar
Congrats.
