Roller Rockers
Old May 3, 2008 | 03:32 PM
lilblackZ28's Avatar
Default Roller Rockers
I am thinking about getting roller rockers for my car but I dont know anything about them.Its a stock 95 LT1 with a CAI,catback,3.73.Where can I get them? how much are they? Are they hard to install? Tell me eveything I need to know and do for them.
Old May 3, 2008 | 04:18 PM
96lt1m6's Avatar
Save time,energy and effort buy these parts and don't look back
New valve springs(918s) drop in w/out major mods
7/16 rocker studs
1.6 rockers for 7/16 studs
hardened push rods
GM guide plates
3/8 studs flex too much at hi RPM......
Old May 3, 2008 | 05:40 PM
BALLSS's Avatar
Crane 10308 springs, Crane 3/8" 1:6 Gold Narrow Body RR, new fel pro valve stem seals.
If you do run the 918's, very good spring, you need to pull the heads and have the spring seats machined down .100". Also if you run "hardened" push rods, and you should with NON self alligning RR, do not use GM guide plates. Get "hardened" ones like ISKY.
Your motor is stock and the 10308 kit is plug & play, no machine work. New valve stem seals since you have tthe springs off.
Invest $15 in a Haynes service book, but a $35 spring compressor and it will take you the day to do it.
You will get a little more power from your stock cam and rev higher with the upgraded springs.
Old May 3, 2008 | 10:00 PM
How much is that kit and where can I get it?
