need help with opti
Old May 4, 2008 | 03:43 PM
19mike84's Avatar
Default need help with opti
well i put on a new opti plugs and wires........ car is missing alot. im going to re-check the wires again. the opti is an msd unit, also my fans are not connected and niether is my water pump. when i put the new opti on it slid right on and sat flush with the timing cover, i didnt have to force it on. also the rotor seemed to be in the same position as the stock one. i would appritiate anyones help
Old May 4, 2008 | 03:48 PM
Badazz 97 TA's Avatar
plug wires on wrong?? happens a lot even when you think your paying attention
Old May 4, 2008 | 03:50 PM
19mike84's Avatar
yeah im going to check it again but i already checked it a few times. i hope im silly and put one on backwards
Old May 4, 2008 | 06:53 PM
Dadic 78's Avatar
Yeah man, sounds like you've got a wire (or two) out of place somewhere. Find a wiring schematic for the plug wires online, or in a Haynes manual, and double check.
Old May 4, 2008 | 08:00 PM
19mike84's Avatar
i have a schematic from msd. according to that i have it hooked up right. i even had my friend look at it too just to make sure. i dont know whats going on. its wierd. i ran it again and it seemed to run better. i dont know ill try again when its dark and see if its arching. its also throwing a code
Old May 4, 2008 | 08:29 PM
ss.slp.ls1's Avatar
What year is the car? Get it scanned and post the codes.
