Gray Smoke.... Fuel????
Old May 9, 2008 | 12:18 AM
Cross's Avatar
Default Gray Smoke.... Fuel????
Well I am still getting some smoke, I replaced my PCV Valve and cleaned it up some of the lines etc. I ordered a catch can so we shall see but those following do not think its oil (Or Blue Smoke).
They say now it looks like Gray smoke and it def smells like fuel at idle... has smelled like that before I started finding what was putting oil in the intake manifold.
So I am looking for some idea's... whats gray smoke? This is a new one on me.
Hopefully I will find when I pull the TB off tomorrow that there is no oil in the IM. But the Oil Catch Can should make sure of that... either way its going on... I just hate this wonderful problem lol.
Old Oct 15, 2010 | 09:37 PM
James Montigny's Avatar
Did you ever find an answer?
Ever since my cam swap mine starts, but idles low and fills the air with gray smoke.
My right O2 shows lean, I figured it was probably ignition-related.
I replaced plugs and wires, looks like I may have to check the injectors and opti.
