Subframe Connector Question?
Old May 13, 2008 | 11:28 PM
camarostripes96's Avatar
From: Academy,Tx (home of temple/academy Drag Strip)
Default Subframe Connector Question?
I have a 96 trans am lt1, and i am looking to get some subframe connectors!! Is it worth it and where could i get some good but cheap ones at? also how do u install them and where do they go?
thanks for the help
if u have pics of some on ur car that would help ALOT!!!
Old May 13, 2008 | 11:54 PM
OutlawZ's Avatar
Right off the bat I'd say BMR...... Some of the best chassis stuff made.... no different for subframe...
They are worth it. They go under the car welded in to connect the front subframe with the rear subframe.....
if you don't have a cage they are VERY worth it and they go a long way towards structural integrity..... Some of the most solid cars i've seen are ones that have had subframe connectors since day 1... find a good welder to do yours..... Most exhaust shops will do them...
Old May 14, 2008 | 06:53 AM
Badazz 97 TA's Avatar
you can buy the bolt in style then have them welded in. it will save you a little money. that way you can install them yourself then just take it to a welder
Old May 14, 2008 | 09:16 AM
Elliott's94Z's Avatar
I don't have any pics but I just put a set of UMI 2-point bolt in and I love them..easy install too.
Old May 14, 2008 | 09:28 AM
XxApollynxX's Avatar
What are peoples thoughts on the 3-points, I was looking at the UMI 3 points.
Old May 14, 2008 | 09:37 AM
They are great as well as the 2-points..They will help better with t-top squeeks..I'm sure they have another plus about them as well. Prob a little stiffer ride then the 2-point. This post really should be in the suspension section..
Old May 14, 2008 | 09:38 AM
If you haven't replaced the factory torque arm or panhard bar yet then I would invest in those first.
Old May 14, 2008 | 10:05 AM
djjab57's Avatar
Im getting the impression that the bolt ons arent as good. Is There A problem people have with them also is the ones you see on ebay any good? Sorry for jumping on your thread like this but im getting some myself so i thought id ask thanks again
Old May 14, 2008 | 10:13 AM
UMM there is nothing wrong with bolt in because you can always weld them in....
Old May 14, 2008 | 11:29 AM
djjab57's Avatar
OK is it not good to just bolt them in thats what i was really asking
Old May 14, 2008 | 11:39 AM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
It is better to have them welded.
Old May 14, 2008 | 11:55 AM
x2...^^^ Haven't got mine welded yet..not sure if I'm going to cause they seem to be holding in well even with me rallying the crap out of it!!
Old May 14, 2008 | 02:28 PM
Spiers's Avatar
We do have a section for Suspension & Brakes...
Subframe connectors are designed to tie the front and rear subframes together, stiffening up the chassis, resulting in improved handling, reduced t-top squeaks, dash rattles and quarter panel flexing. A piece that is designed to add rigitity to your car must be welded in to do that best as possible. A flange that is retained with just a bolt can still flex from the point of the bolt retaining it...
Old May 14, 2008 | 02:29 PM
imnotplutonium's Avatar
BMR.
I had mine put in when a friend with a '96 ws6 had been at the track a few times and after some hard launches said his t-tops did not fit well anymore and had leaking issues. Put mine it and the integrity is much better.
Old May 14, 2008 | 11:22 PM
Formula350's Avatar
I bought some off eBay for my 91, and me and my friend couldn't figure them out. They were a POS though Just a long piece of box steel with a piece of flat stock welded on one side with holes for bolts. The "instructions" that came with it pictures it going to the transmission area, but there was no way it would've worked lol.
I'd love to make my own (as well as a strut brace), but don't know where I could get thick tubing bent :\ I'm poor, and can't afford a nice $100-200 set of SFCs.
