how hard are dauls
I'm not as happy with my MAC/ORY/Flowmouth setup as I thought I'd be. So I'm thinking about the new TSP 1 7/8" LTs and 3" mandrel bent TDs with two Super 44s right in front of the tips.
Do I just need to go to another exhaust shop?
would you want it dumped before the axle, or done over the axle? i just recently saw someone on here do a setup with oval piping. that would definitely help clearance issues. dumped before the axle is pretty simple, so that shouldn't be too big of a job, which really means "not too big of a check."
And as far as a price for duals, there's a lot of different factors involved... what size piping are you going to run? What mufflers are you going to use? Are you going to do it yourself or have a shop do it? What shop? Is it going to be dumped at the axle? Or ran over the axle? Or ran under the axle?
BUT if you want to do it more power to you, I do agree that if you want to do it, do it right. Oval pipe will help out lots with clearance. I have clearance issues and I do not even run duals.
Another drawback is that the car hardly ever stays clean from the dust being blown up from the ground.
The best advice is to go ORY, 3" mandrel bent, cut out, over the axle, (insert your favorite muffler here) and a couple of sweet tips.
So
, where's the best place to get an ORY? Yeah, yeah..I know...
(for all you "search" police) oval piping is very expensive but like others have said, there is the right way to do it and the other way....
and did the OP say you're going to do turndowns prior to the axle using the stock tips????? I don't even know what to say about that if that's what your intention is.....
Here is my write up on my pipes that I haven't scraped:
http://www.lt1engine.com/tech/how-to...duals-exhaust/
And the "I know I've seen 3" run over the axle, but I can't seem to find anymore pics of it":
http://www.lt1engine.com/?level=album&id=7&plog_page=2
