Exhaust Change...
Old May 24, 2008 | 01:14 AM
95CamZ's Avatar
Default Exhaust Change...
I have had my LTs and ORY into a dynomax bullet dumped before the axel for a few months now, and i'm thinking about changing to an x-pipe but am unsure who to get it from and also what mufflers to go with! Please give me some suggestions.
Old May 24, 2008 | 08:24 AM
Spiers's Avatar
You can purchase an x-pipe from Summit Racing, and as far as mufflers there are plenty of choices, depends on the sound you want... Moroso spiro flows, Flowmaster 10-chambers, Dynomax bullets, Borla XR-1, etc....
Old May 24, 2008 | 09:44 AM
InsaneAuto86's Avatar
I have the summit 3" x-pipe kit with dual dynomax bullet shorty mufflers dumped at the axle. very nice!
Old May 24, 2008 | 02:28 PM
IronOutlaw's Avatar
ive run both morosos and flowmaster 10s. the moroso had a better wot scream and i loved that, but they just werent smooth down low while idling and cruising like the flowmasters are that i have now. but they are both verry loud
Old May 25, 2008 | 01:06 PM
95CamZ's Avatar
So these would work?
http://www.jegs.com/p/JEGS/755652/10002/-1/11525
http://www.jegs.com/p/Flowtech/845085/10002/-1/11525
Old May 25, 2008 | 01:17 PM
mean_greenZ's Avatar
what about chambered mufflers?
and yes either of those would work.
Old May 25, 2008 | 01:50 PM
95CamZ's Avatar
I'm open to anything at this point just like ironoutlaw said the dynomax bullet on it right now only sounds good to me at wot, so i'm looking for something that is loud but sounds good all around!
Formula350's Avatar
I don't know if you are good with welding and the like, but you could always make your own if you plan to do the X-Pipe install yourself. Or, I'm SURE there is at least ONE shop around that has a guy skilled enough to do an X-Pipe. I know there's a couple places by me who can. I'd think that it would be cheaper for a side-shop with a guru to do it. I had an H-Pipe put in my old Suburban and, while it's just a normal connecting pipe between the duals, it needed some work and to be bent, but it only cost me $25. He did all the work.
Old May 25, 2008 | 01:51 PM
95CamZ's Avatar
Also my ory is 3in should i go with 2.5 or 3 with the x-pipe?
Old May 25, 2008 | 01:52 PM
Formula350's Avatar
I don't know anything about X Pipping, but my assumption would be that 2.5 would be a bit more throaty than 3", and if you went any smaller it would add some rasp to it. I only make this comment in hopes someone will chime in with info about it, since I'm curious.
95CamZ's Avatar
I was going to do the work, but hell if i can find someone to do it for 25 dollars i would jump on it.
Old May 27, 2008 | 10:50 AM
95CamZ's Avatar
Anybody on what i should get 2.5 or 3?
Old May 27, 2008 | 12:02 PM
lt1noob's Avatar
id go with 3 inch if your going to continue modding (which im sure you will because its so damn addicting...)
also id check summit or jegs, i beleive they both carry x pipes.
Old May 27, 2008 | 07:36 PM
IronOutlaw's Avatar
i like how ive got stock clearance with my 2.5 inch exhaust. but im not planning on going over 400 rwhp though.
