Someone Killed My T/A
Bummer you had it just rebuilt
BUT! Even if it did damage the piston too much, with it just being re-done I bet you could get away with 1 piston and a hone job on that cylinder and be fine and dandy. That's probably worse case I can think of. Other than MAYBE damaging the head/valves in that cyl as well.As for being stressed, I understand, I just thought it was funny even though it makes sense since there IS fire in the cyl and they are still walls
I'll let someone else agree, or correct me though, but I'm 90% sure that's as hard as it is.
Thanks
Thanks
That and me preferred Ammo is 12ga Rocksalt Rounds..
You should get the new shotgun that can fire all 8/9 rounds in like 5seconds (basically as fast as you can pull the trigger)
Sorry for loss, man that really sux. I would really wanna killem after that.
Wohoo! 1000th post, and 4 years here at LS1tech!
I recomment 12 gauge tripple ot buck shot, just aim away from anything you care about. and make the gauge a pump all know that sound of a gauge being loaded..
