Quick question
Old May 25, 2008 | 12:13 AM
Teal94Z's Avatar
Default Quick question
what socket is needed to remove the cap and rotor on an 94 lt1.
Old May 25, 2008 | 01:39 AM
BigZee71's Avatar
inverted T4?
Look on ebay *** some of the ebay opti's come with the correct bit to remove the cap and it gives the size of the socket that comes with it.
Old May 25, 2008 | 02:36 AM
porksoda's Avatar
The bit is pretty hard to come by but in a pinch you can do this: http://www.lt1engine.com/tech/085-opti-cap-rotor-tool/
Old May 25, 2008 | 11:34 AM
Dadic 78's Avatar
Originally Posted by BigZee71
inverted T4?
you got it!
If you buy an MSD cap/rotor kit, it will come with the tool you need.
To save money, you can buy a #4 TORX bolt, flip it, and use some vise-grips to remove the E4 bolts. Cost you $0.25 for the bolt!
