Stock 10 bolt? How much abuse will it take?
Old May 29, 2008 | 04:13 PM
Ihasfip's Avatar
Also I am new to f-bodies...what 12 bolt rear will interchange...if any?
Old May 29, 2008 | 04:20 PM
Slowmaro95Z28's Avatar
None. You have to either weld brackets on one or buy one that already fits. No cars that I know of with 12 bolts were set up for torque arms, panhard bars, or our style of lower control arms. Someone else may be able to help you on where to find one.
Old May 29, 2008 | 04:24 PM
SS MPSTR's Avatar
Strange and Moser make 12-bolts that actually 'bolt-in'.
Old May 29, 2008 | 04:39 PM
Ihasfip's Avatar
Yea but I bet strange and moser **** is expensive. Cheaper to build a 10 bolt?
Old May 29, 2008 | 04:49 PM
Ihasfip's Avatar
And what actually breaks on these 10 bolts when they go? Carrier? Gears? Axles them selves?
Old May 29, 2008 | 05:26 PM
the_merv's Avatar
Spiders Gears are usually the first to go. I have destroyed a Ring and Pinion also.
I priced out a 9" Conversion using a Moser Housing& Axles, a Carrier from www.nationaldrivetrain.com , and 3.73 Gears plus the proper Shim kit, it came out to a little under $1900. The Strange setups are a little more..
Personally I would go with the 9", there is more parts out there for it, and they are cheaper.
Old May 29, 2008 | 05:29 PM
Ihasfip's Avatar
So can't I fix that by just putting a spool in it? A stock lt1 shouldn't be able to break a spool or axle shafts should it? On drag radials?
Old May 29, 2008 | 06:01 PM
LM97Z's Avatar
A spool will make it stronger, but its still a 7.5" rear, even if the engine is mild, its still a matter of time before something lets loose with a 6sp. & Stickies, i could've gone this route with my 10 bolt, beefed it up good for say what 600.00, but its still not near as strong as a 9", so i'm out an extra 800.00 for a moser houseing/axle package & a completely re-built Trac-lock 31 spline 3rd. member with new bearings/clutches, i'll take that insurance anyday, i just dropped my 10 bolt on the ground today , thats where it belongs lol. If my poor azz can scimp & save for a 9", anyone can.
Old May 29, 2008 | 06:24 PM
Ihasfip's Avatar
Well if 800$ is all it would cost to put a 9" under my car then thats not bad...I figured around 2k for a 9". Is that complete end to end? And does it use the stock brakes ? Now if you are saying it cost say 1400$ then I will put a spool in it and drive it til it breakes....
Old May 29, 2008 | 06:32 PM
Skidd's Avatar
No way you could do one for 800 unless you do all the fab work on the brackets yourself on a junk yard pull out. You could probably come up with a used one cheaper than buying new one. http://www.mofbody.com/forums/viewto...er=asc&start=0
Old May 29, 2008 | 06:53 PM
Ihasfip's Avatar
Ok thats what I thought... im new to f-bodies but not to cars and that was way cheap. so looks like a spool for now. til it breaks...nine inch is better than the 12 bolt right ? more money too ? **** it. ill just strap some leaf springs and my 14 bolt with detroit out of my rockcrawler. lol
Old May 29, 2008 | 07:50 PM
  #32
LM97Z's Avatar
I was meaning 1400.00, 1000.00 for the moser houseing/axle package & 418.00 (shipped) for the complete 3rd. member, so i deducted a guesstament of 600.00 for a beefed up 10 bolt, thats where i came up with the left over 800.00, well 818.00 to be exact. If you really do this with the 10 bolt, i wouldn't put much into it, say just a gear change & be done, what sucks is its just a 50/50 chance of WHEN it will break, not IF. thats a chance i myself didn't want to take, i'm new to these cars also, i didn't realize how soft of a rearend these cars had, if i did, i would have gone with an automatic, but i really wanted a stick, so here i am paying the price lol.
Old May 29, 2008 | 08:12 PM
  #33
Ihasfip's Avatar
got gears just need the spool. then well see how long it lasts. i should have got another fox .
Old May 29, 2008 | 08:28 PM
  #34
CamaroRacing12's Avatar
<<< my stock 10 bolt has gone 1.70 60fts and has taken them like a champ....... so far
Old May 29, 2008 | 08:48 PM
  #35
LM97Z's Avatar
I'm guessing you have an automatic, if so, i'm not at all surprized its holding up, & i'm sure it will for awhile running 12s
Old May 29, 2008 | 10:09 PM
  #36
the_merv's Avatar
^^It's in his sig..he's got a Yank SS3600.
Old May 30, 2008 | 10:09 AM
  #37
Spiers's Avatar
Originally Posted by BattleShip
9.009 is DAMN good for a CAI, 4.11 and a stick. That mph seems wrong, I was running 7.8X with 88 mph have a feeling yours should be ~78 mph.
Regardless 9.00 is really good considering that most stock LS Camaro's ~9.2 in 1/8
I ran a 9.09@79.6 with a 2.27 60ft BONE stock in my car. Only mod was a misfire from a bad optispark.
Old May 30, 2008 | 11:22 AM
  #38
Ihasfip's Avatar
Yea thats what I thought...seemed kinda slow for me....1/8th mile is gay. Not set up for that...and I possibly would have ran better times on street tires cause I could have launched at a higher rpm and feathered the throttle til I got out of the hole. I also just dumped the clutch if I would have feathered it out of the hole it might have done better I don't know, I don't claim to be a drag racer.
Old May 30, 2008 | 02:00 PM
  #39
Does anyone know how much stronger the carrier out of an LS1 rear is? They seem to hold up way longer than LT1 cariers. I blew my stock rear when my car only had a cai and flowmaster muffler.
Old May 30, 2008 | 02:16 PM
  #40
the_merv's Avatar
That's cause they don't have the miles and years of abuse on them..
I think the LS1's had a different Carries actually..
