will i hit the 12's?
Old May 29, 2008 | 04:20 PM
CamaroRacing12's Avatar
<<< i spent around $3k this winter on my CPT Pro race rebuild, brand new yank SS3600, cooler, and all the odds and ends.... **** adds up.... always over estimate the cost
Old May 29, 2008 | 09:08 PM
robsquikz28's Avatar
nope need more mods
Old May 29, 2008 | 09:27 PM
1badzee's Avatar
My buddy spent like 2400k.. depends though. over estimate the cost for sure
Old May 30, 2008 | 11:06 AM
EliteCamaro94's Avatar
so with full exhaust cold air, a built tranny, a cam and good suspension mods, and 4.10 gears and sticky tires i should hit 12's?
Old May 30, 2008 | 05:34 PM
LT1_T/A's Avatar
yeah that sounds more like it......
Old May 30, 2008 | 08:30 PM
LSWHO's Avatar
You should see LOW 12s with all that. Where are you racing? Speedworld or firebird? I always found speedworld has faster times.
Old May 30, 2008 | 11:28 PM
LT1_T/A's Avatar
i dont think it will be low 12's but you will definitely be in the 12's....do you plan on getting a tune?
Old May 30, 2008 | 11:42 PM
30thanniversaryz's Avatar
Originally Posted by TABBED 5.3
i would say more than that or my car is just slow. my mods currently are moroso cai, bbk throttle body, bbk shorties w/stock y with cats, flowmaster, madz28 tune, moser 12 bolt with 4.10s and mt dr i ran an 8.85 on a crappy track with bad air. that is about a 13.6 according to the calculator, oh yeah and some weight reduction
I ran an 8.755 with just CAI and exhaust...
Old May 31, 2008 | 11:57 AM
LSWHO's Avatar
Come on! If you can't get a CAMMED v8 past high 12s you shouldn't be racing or you need a lower altitude track.
That's just pathetic. If my car couldn't do low 12s after a cam, I'd sell the damned thing. That is COMPLETE driver error.
Old May 31, 2008 | 12:32 PM
i agree... i would park it on a deserted road and toss the keys into an empty field and walk away from it hahaha
look at my times... bolt ons only 12.61 @ 106mph and in the 1/8th i ran a 7.99
Old May 31, 2008 | 01:38 PM
lt1-xjs's Avatar
I agree, bolt-on's is all you should need.... Right weight ? I wish.
Old May 31, 2008 | 03:48 PM
  #32
LT1_T/A's Avatar
lswho i didnt say he cant get past high 12's i just said i didnt think he would be in the low 12's.
Old Jun 1, 2008 | 12:14 AM
  #33
disiac5.7's Avatar
+1
I went 13.00 @ 107 with just LTs, CAI, and ET Streets. Pull the front sway bar and I would've been 12s no problem.
Old Jun 1, 2008 | 01:35 AM
  #34
LSWHO's Avatar
With a good launch he should be.
Old Jun 1, 2008 | 01:42 AM
  #35
Fixxer99TA's Avatar
Radials + Driver mod with that setup should = 12s
Unless of course theres something wrong with the car....
Edit : A stall would be pretty rockin' aswell.....
Old Jun 1, 2008 | 01:50 AM
  #36
LM97Z's Avatar
I think 13.0 is a know brainer with bolt-ons & good 60ft. times, i saw a half assed bolt-on 94 Z auto run 13.2s & 102, but his 60 fts. were in the 1.8s, with my bolt-on high mileaged pig (158K), i ran a 13.7 @ 101 with a 2.17 with street tires & good DA, that was with the 3.42 gears, with a 1.9 (which is doable), i'd be in the 13.4 range in the same DA, i wasen't a believer that these cars had it in it, untill i started getting my driveing under control, i don't even have a tune, still running off the stock pump/opti, once i get this 9" in, i'll be installing some MT Radials & looking for those 1.86-1.88 60fts @ 13.3s, thats with a 3.50 gear, with a tune @ cam change, 12.9s should be know problem.
Old Jun 1, 2008 | 04:36 PM
  #37
LT1_T/A's Avatar
We'll see
Old Jun 1, 2008 | 05:36 PM
  #38
PNYKLR-TA's Avatar
really everyone i have heard from says firebird has the better hole. i've also heard of peoples 60' being much slower out at speedworld cause the box is just too slick.
Old Jun 1, 2008 | 06:15 PM
  #39
wnaplay96z28's Avatar
I have a 96 Z28 T56, I have every bolt on that dose not touch oil. I have a home made 3" cold air intake, 1 7/8 Hooker long tube headers, no cats, 3" Y-Pipe, 3" exhaust all the way out the back, stock tune in the computer, LT4 Knock sensor, Centerforce Dual Friction clutch, ported MAS, Intake coolant by pass 4:10 gears!!! I put 291WRHP AND 321RWTQ and ran 12.89 at the track!
We'll see
Old Jun 1, 2008 | 06:53 PM
  #40
LSWHO's Avatar
Personally, I've always done MUCH better at speedworld in the 60' 9 out of ten times my launch is perfect there, or close to it.
The only thing I can think of is maybe it sucks with DRs or slicks, cause I've NEVER used anything but street tires.
