SES light and emissions testing question for a 97 LT1
Should the car pass if I clear the codes and have it tested with no codes showing up? The SES light takes a long time to come back on.
I noticed that the scanner says incomplete for the o2 tests that it does which makes me think that it might fail at the testing station because of not enough information.
Clear the codes and take it in. It may pop something before the ses comes on at which point they ask you to get a different gas cap or take it off then put it back on.
Years of that messing around and the 97' keeps getting it's tags renewed.
When you clear the codes it will set all those tests to un-checked. It may be less of a hassle to just replace the sensor.
