Help: 97 lt1 overheating randomly
Old Jun 3, 2008 | 05:24 PM
blubyu02's Avatar
Default Help: 97 lt1 overheating randomly
My trans-am started overheating all of a sudden, granted i just bought the car but the guy said it never overheated so i took his word for it. it has new radiator on it. But i was driving down the road in town and notice the temp guage go up almost to the 3rd white line 3/4 mark. and the check guage light came on. i immediatly pull over and nothing is leaking but i can hear how hot it is. The fans are popping on and everything so anywayz i get on the highway and it stays at 210 just a **** hair under but as soon as i get back to town it steadily starts to rise anyone had this problem b4? i would like to try and fix it myself b4 i take it to some mechanic that will charge me an arm and leg just to diagnose it. im hoping its just a thermostat or something little like that any info/help would be greatly appreciated thanks alot............
Old Jun 3, 2008 | 05:59 PM
stfuad's Avatar
take the thermostat out and test it.
make sure the air flap under the car is still there.
make sure teh radiator isn't blocked by stuff.
Old Jun 3, 2008 | 06:02 PM
AKAFRED's Avatar
try bleeding the system there should be a bleeder screw in thermostat housing and one on the heater line.
also verify that both fans are coming on.
Old Jun 3, 2008 | 06:06 PM
TXFORMULA's Avatar
a low temp (160*) thermostat will fix that but you need a tune or a manual fan switch so that the fans will cut on earlier. mine did exactly what you are talking about on the way home with it. they are just tuned to run hot from the factory.my coolant boiled right up out of the recovery tank. i parked it until my thermostat and tune got to me and with that it hasnt done it since
Old Jun 3, 2008 | 06:47 PM
DAVE00's Avatar
Bleed the system, as this sounds like air in the system. Since it has a new radiator I would suspect this first.
Old Jun 3, 2008 | 10:58 PM
blubyu02's Avatar
thanks everyone thats what ima spend my whole day doing tommorow, txformula where do you get a tune from? or are you talking bout an all out tune for the car?
Old Jun 4, 2008 | 01:56 AM
BLK,97,T/A,M-6's Avatar
Blockage.
Old Jun 4, 2008 | 07:33 AM
blubyu02's Avatar
blockage???
Old Jun 4, 2008 | 07:48 AM
stfuad's Avatar
Something blocking the radiator, internal or external.
Old Jun 4, 2008 | 11:49 AM
black_sunshine's Avatar
other things to check is the rad. cap pressure. is the water pump moving water? did you happen to notice if the thermostat is working when you were driving?
Old Jun 4, 2008 | 01:40 PM
blubyu02's Avatar
Ok i took the thermostat completly out and it isnt overheating but it goes right around 210 and then goes back down i went to buy a 160 degree thermostat and they didnt have any so i just got another 180 until i can find a 160. the radiatior cap is my next thing to check
Old Jun 4, 2008 | 01:44 PM
emj2006's Avatar
Based on experience.. make sure theres enought coolant in there also.. same thing happened to me and there wasn't enough coolant. I added coolant and it all went away..
Old Jun 4, 2008 | 01:54 PM
blubyu02's Avatar
yeah i checked all of that stuff right off the bat yesterday when it happened i had to add a little but not much i filled the resivour i hear people say that when this happened to me that fluied came pouring out and all that but it didnt to mine i could hear it boiling inside the motor tho..........
Old Jun 4, 2008 | 02:27 PM
blubyu02's Avatar
ok i put the thermostat back in and it started doing the same overheating thing, so that rules that out what could be next?
Old Jun 4, 2008 | 02:33 PM
stfuad's Avatar
Did you bleed the cooling system? Is your air dam in place? Is the radiator coated in bugs (plastics bags, etc...)?
Get a coolant pressure testing system.
Old Jun 4, 2008 | 03:57 PM
blubyu02's Avatar
yeah everything is in place the radiator isnt bad at all. I turned the ac on and it stayed right around 210 but with the ac off it goes outrageous. but i hear the fans coming on at idle so idk what the deal is, i think ima go ahead and take it to the shop and let em fix it
Old Jun 4, 2008 | 04:19 PM
lt1taracing's Avatar
like others have said, bleed the system. with the car cut off and the radiator cap off fill radiator to top and crack the bleeders one at a time. if it has air you should here it. it might take several times. when its full, water and or antifreeze will run out. you'll have to keep adding water till its completely bled. also, the secondary fan cuts on when the a/c is on. your primary fan may not be working. this is very common. either the ground or hot wire is not making a good connection to the fan. check both. you can also run your primary fan to a relay and then to a manual switch. you also mentioned that it had a new radiator. make sure the small hose directly under the cap is going to the overflow. i've seen some guys mistakenly have it backwards with the early lt1s and run it the engine. this will cause temp problems.
Old Jun 4, 2008 | 04:57 PM
blubyu02's Avatar
ima go bleed it and check the fan grounding wires make sure everything is getting good connection thanks for da info lt1ta................
Old Jun 4, 2008 | 06:18 PM
PNYKLR-TA's Avatar
all i would say is get a tune. i live in phoenix az and my car frequently went to about 210 (hardly ever over) but the second fan isnt supposed to kick on until like 215 or some outrageous number. i got a tune and now the car never goes about 185. in dead stop in 110 degree weather it sits right at 185 then right as soon as i start driving again it goes to like 165. and a tune can or pretty much has to be a mail order tune, unless you know someone close with tuner cat or lt1 edit.
Old Jun 4, 2008 | 06:55 PM
slow and da curious's Avatar
Just curious why it has a NEW radiator in it and the guy says it never overheated on him. Obviously it did something to warrant a new radiator. Mine ran warmer than I liked when I bought it too. It would stay around 190* while driving, but if I sat at a long red light, it would go over 200. But after a 160 stat and tune, the car never sees 185 now.
