help! car died and wont start!!!!!
Old Jun 6, 2008 | 10:36 PM
4SFEDZ's Avatar
Default help! car died and wont start!!!!!
ok i have a 94 camaro with a 385, fully built, tti front mount with a 76mm turbo, its a 6speed, new opti. ok. tonight i was driving home and ev erything has been perfect up till now and the car started sputtering, missfiring, or something. i could fell and hear it. it felt like i was running out of gas but wasnt. my fuel pressure looked fine, on my gauge and a/f seemed ok bout 13.5 cruising. well the stumbling/missing started geting worse and when i let it idel it backfired a little, and wanted to die, but i gave itgas and it didnt. got home and it died and wont start. wtf!!!!! i have noticed it taking longer to start also, turns over more than ussual. what do yall think?
Old Jun 6, 2008 | 10:46 PM
djjab57's Avatar
i would start by checking the coil and the icm but it sounds like the coil to me
Old Jun 7, 2008 | 11:12 AM
4SFEDZ's Avatar
coil is brand new!!!
Old Jun 7, 2008 | 12:45 PM
4SFEDZ's Avatar
ok i went and got it started today, but i had to hold the gas pedel all the way down and it started, it seems to be smoking a bit, and it is pullin a little less vac than ussual. could fouled plus do this, what bout o2's?
Old Jun 7, 2008 | 01:24 PM
djjab57's Avatar
i just bought one from summit racing it lasted for less than a min. before it went bad i just sent it back, hope you can figure it out
Old Jun 7, 2008 | 03:55 PM
4SFEDZ's Avatar
thanks!
Old Jun 7, 2008 | 05:35 PM
Formula350's Avatar
Check your TPS voltage and IAC count.
Old Jun 8, 2008 | 01:39 PM
4SFEDZ's Avatar
think im just goin to replace the tps, its an old one so why not. think im goin to get new o2's and spark plugs also, if that dont do it ill get a new coil.
