Couple questions
Old Jun 9, 2008 | 12:43 PM
MTBSully's Avatar
Default Couple questions
My head gasket comes tommorow morning and i just finished cleaning the old gasket off the block with a razor blade and some brake cleaner. The past couple days it has been really hot and humid, and i just noticed that there is some rust developing on the inside of the cylinder walls. Should i just scrub it with some brake cleaner and assume that the rest will burn off at start-up?
Also doing my wires, and i noticed behind the pulley of the PS pump there appears to be an area to route all of your plug wires. Is this where you guys run yours? It seems like my #2 plug wire won't reach if i go that route, but then again its hard to tell with the head off. Thanks guys
