my car is posessed
Old Jun 10, 2008 | 01:43 AM
Revelation Z28's Avatar
Default my car is posessed
officially!
if i let the car sit for more than 2 days (weekend) itll leak a little coolant about an ounce from somewhere on the passenger side of the engine and dribble on the plug wire boots, and drip onto the swaybar. away from the opti. this only happens as its warming up.
maybe its crying because im using it again?
thing is, i dont know where the hell its coming from. t-stat housing is dry, WP bolts are dry, i re routed the weep hole (topic about it) and the hoses/bleeders are tight.
Old Jun 10, 2008 | 02:10 AM
Formula350's Avatar
Hose having a pinhole maybe? Heater or Radiator, but any of them could be the culprit.
Old Jun 10, 2008 | 02:27 AM
carlos64030's Avatar
Be sure your coolant bleeder screws are closed completely.
Old Jun 10, 2008 | 02:32 AM
everything is tight! i dont even see a trace of wetness from the pump or anywhere
once i drive it it goes away completely until it sits again
Old Jun 10, 2008 | 03:26 PM
formula1785's Avatar
The Seal For The Camshaft To The Water Pump Is One Common Thing For Leaks In The Lt1
Old Jun 10, 2008 | 05:06 PM
yea but coolant doesnt come out of there.
Old Jun 10, 2008 | 05:10 PM
oifish's Avatar
could be the heater core? I know that they can leak and cause a puddle but that is usually in the inside.
Old Jun 10, 2008 | 05:25 PM
doubt that. looked like it was coming from where the plug wires come from how i routed them ovtc
Old Jun 10, 2008 | 08:37 PM
1badzee's Avatar
If a mechanic can't help, an exorcist usually can... lt1 for the win
Old Jun 10, 2008 | 08:47 PM
Could the coolant possibly be coming from one of the lines on the intake or throttle body?
Old Jun 10, 2008 | 09:41 PM
its dry up there too.
Old Jun 11, 2008 | 03:27 AM
phirepower's Avatar
Coolant leak down test= Solution, if not they sell liquids that you put in the radiator and run through the system, that will glow under a blacklight. You can find them at any decent auto parts store
Old Jun 11, 2008 | 12:52 PM
AronZ28's Avatar
Take some soapy water and run it all over your rubber coolant/radiator hoses. If one of them has a small leak, it will bubble up.
Old Jun 11, 2008 | 02:33 PM
i gotta wait until i let it sit again for 4 days. dont know when.
Old Jun 11, 2008 | 08:10 PM
383lt1impala's Avatar
get an ls1!!! already
Old Jun 16, 2008 | 07:12 PM
found it. its coming from the heater hose on the left top side of the waterpump. anyone have an idea of how i can take it off the pump with minimal coolant loss?
