LS1 intake conversion help + pics!
Old Jun 12, 2008 | 03:48 PM
InsaneAuto86's Avatar
Default LS1 intake conversion help + pics!
I need a better way to connect the MAF to the lid. The angle is really off. I currently have a rubber 4" to 3" reducer from Lowe's. What should I do? Also, should I cut the rad support circled in red for increased air flow? Thanks, Matt
Old Jun 12, 2008 | 03:51 PM
Formula350's Avatar
Personally, I would trim the reducer on both ends as much as you can while still getting a seal and buy another rubber adapter from the box to the MAF. Even the LS motors from what I've seen have an angle to them (or factory ram air LTx)
Old Jun 12, 2008 | 03:57 PM
Well the problem is that the Lid is designed so the MAF slips into it. How would I connect the MAF to the lid with another rubber adapter? (not sure if I described that correctly)
Old Jun 12, 2008 | 04:27 PM
Going with Formula350's idea, I think I will cut about .5" off the rubber coupler and get a small section of 3.5" tubing/pipe to connect the MAF to the lid. I can angle the new section to straighten out the MAF. Should I try to find some 3.5" PVC or aluminum tubing?...
Old Jun 12, 2008 | 04:39 PM
blitzed96's Avatar
I used a hump setion to connect the maf.
Old Jun 12, 2008 | 04:50 PM
Got a pic?
Old Jun 12, 2008 | 04:52 PM
blitzed96's Avatar
Old Jun 12, 2008 | 05:05 PM
Is that referred to as a bellow? Or... Where did you buy it?
Old Jun 12, 2008 | 05:48 PM
blitzed96's Avatar
I ordered it from ebay. Type in silicone hump or something and you will find it.
Old Jun 12, 2008 | 07:21 PM
daniel6718's Avatar
yah and your maf to tb shoulda been 4to4 not 4to3
Old Jun 12, 2008 | 09:46 PM
LT1 chevelle's Avatar
go to the website jags that run jtr.com I think. They have all kinds of elbows, fittings and other pipes that might be helpful.
Old Jun 13, 2008 | 11:18 AM
The 4" to 3" worked fine... I will get a 4x4 and see.
Old Jun 13, 2008 | 11:25 AM
Tireburnin's Avatar
Buy a 2-3 inch long piece of silicone hose from anywhere in 4 inch size. I used the piece that came with my Trickflow elbow.
Old Jun 13, 2008 | 11:44 AM
Formula350's Avatar
It just looks a bit flared out on the MAF side.
Old Jun 13, 2008 | 11:47 AM
LTBANDIT's Avatar
i'm disappointed! i thought someone actually figured out how to put the composite intake manifold from the ls1 on the lt1...
Old Jun 13, 2008 | 03:17 PM
Formula350's Avatar
heh Basically impossible due to the O-O-O-O port design compared to out O-OO-O
