fans stuck on
Old Jun 15, 2008 | 09:35 AM
goinfast's Avatar
Default fans stuck on
so my fans wont turn off i pulled all the relays and fuses still wont shut off its a 93z28
Old Jun 15, 2008 | 10:59 AM
Formula350's Avatar
lol You had to of pulled the wrong relays then. The relays, well, relay power when they click on. W/o them, there's no way for power to get from point A to point B in the relay box unless its arcing across, but that would cause a fire and not spin the fans properly.
Old Jun 15, 2008 | 11:01 AM
landstuhltaylor's Avatar
Is your check engine light on? That will cause the fans to stay on as long as the correct relays are not pulled.
Old Jun 15, 2008 | 09:20 PM
goinfast's Avatar
ya i didnt pull the right one im a retard. i have no check engine light on. i tried another relay and they stay on. could it be the temp sensor?
