Losing tach signal.
Old Jun 16, 2008 | 11:52 AM
MEAN LT1's Avatar
Default Losing tach signal.
It seems the higher the motor spins up my tach gets jumpy. It usally happends in the higher rpms bands like 5700 and up. I went tot he track recently and when Ithought I was shifting at 6500 I was only shifting at 5800-6100. Anyone else experience this?. I guess the only way to prevent this is to get a shift light or aftermarket tach.
Old Jun 16, 2008 | 02:08 PM
Formula350's Avatar
Everyone says the tach is around 200rpms off, yet time and time again, mine is reading the exact same as the ECM :\ Mine's a fluke I guess.
So anyways, it's probably that your gauge just is off like the rest. Run your own wire and tach from the coil if you don't like it lol It's only 1 wire.
Old Jun 16, 2008 | 03:28 PM
MEAN LT1's Avatar
What sucks is that I logged all my runs from the track on saterday. When the tached showed around 6500 rpms. Per Datamaster it was only 6000 or in most cases 5800.
Old Jun 16, 2008 | 06:31 PM
Smokeshow_2006's Avatar
Mine has a conditional missfire, with tach jump. Still in the process of diagnosing. Only difference, Mine will jump all over, from idle, to wot.
Old Jun 16, 2008 | 07:45 PM
Formula350's Avatar
hah I really don't know what to tell you then :\
