Stock Rod Strength
Old Jun 16, 2008 | 02:12 PM
Lt1_93z's Avatar
Default Stock Rod Strength
Just how strong are the stock rods for lt1 motors? I am in the middle of a build and would like to go with a 3.75 eagle crank and forged pistons but were wondering if the rods are good to go given that I don't spin over 6,600 rpm...The car will not make over 400rwhp at this time also...
Thank you
Old Jun 16, 2008 | 02:17 PM
ulakovic22's Avatar
Stock rods are fine for your current build. They, like the stock crank, can handle a good amount of power.
Old Jun 16, 2008 | 03:35 PM
wrd1972's Avatar
Stock powdered metal rods are very strong, its the stock rod bolts that suck and should at the least be replaced with ARP's.
Old Jun 16, 2008 | 07:08 PM
transamws6_97's Avatar
yeah the weak link is the rod bolts...the higher you spin the motor the more force on the bolts and cause them to distort and that causes wear and tear on the bearings. Get some good arp bolts and you should be good to go.
