??? Best clutch & flywheel to use ???
Centerforce dual friction has been tried and disliked!
LT1 SETUP
THANKS!!!
Make sure if you go aluminum your torque multiplication (first tranny gear ratio multiplied by the rear end gear ratio) is 11 or more or else you will have a dog off the line. Example my new setup: first tranny gear is 2.66 and the rear is 4.88. 2.66x4.88=12.9808
. My old setup 2.52x3.31=8.41932
. Not so good with aluminum. If you are under 11 stick with a steel flywheel which you can also get with the street twin.
