383 Specification Questions...
Old Jun 25, 2008 | 12:15 AM
Lt1_93z's Avatar
Default 383 Specification Questions...
I'm currently building a 383 stroker and I am doing the work with the exception of having the machine work and crank clearancing done at a machine shop. I am using the Lt1 Engine specifications guide at shbox.com. Here are my questions:
1) Can I use the factory ring gapping specs?
2) Can I use the factory bearing clearance specs?
3) Will I have any issue running 93 octane with 11.8:1 compression?
Thanks alot guys!
Old Jun 25, 2008 | 11:25 AM
96redcamaro's Avatar
Thanks alot guys!
1: i think that really depends on what you plan on doing with the car N20 and what not.
3: yup 11.8:1 will be fine.
Old Jul 2, 2008 | 12:11 PM
connexion2005's Avatar
Like mentioned factory ring gaps and bearing clearances are perfectly fine for running a n/a setup. If you plan on boosting or running nitrous simply call the manufactures for those products and they can recommend you and ideal gap. I still recommend building it with bearing clearances just like stock specs. Your on the verge for compression but a good tuner can make it work just fine. DCR is actually more important than the SCR you've listed...Shoot for a DCR under 9.5:1 for pump gas. Empirenet.com has a good calculator you can use and just google for any specs you don't have for the calculations...
