Optispark Options For My 93 Lt1
Old Jun 27, 2008 | 05:03 PM
Harleyguy's Avatar
Default Optispark Options For My 93 Lt1
I am presently rebuiding my 93 LT1 and wanted to know if I changed the cam and timing cover if I could use a 95 optispark on my 93 harness.
Old Jun 27, 2008 | 06:18 PM
Speed Density's Avatar
hashtagBMW
Nope.
You need the 95+ vented opti harness. Casper electronics sells them via summitracing.com its like $25.
Its basicly the same harness, but the opti end goes deeper into the optispark.
Old Jun 27, 2008 | 06:26 PM
Smokeshow_2006's Avatar
hijack...
Best place to get a new harness?
Im replacing my msd POS with a delco and need a new harness...
Old Jun 27, 2008 | 06:34 PM
hashtagBMW
I got mine at summit. You could probly get it in town though.
Old Jun 27, 2008 | 06:35 PM
litch2004's Avatar
if i were you i would go ahead and spend the extra money and buy the msd probillet ignition it has +/-7% timing offset. plus it comes with the harness and all the vented tubes. Plus it is rateds a lot higher than the stock one. I found that our the hard way. I have had mine on my 93 T/A for over a year now and still just as happy with it
Old Jun 27, 2008 | 06:36 PM
My msd unit crapped out after 8,000 miles. Not a good investment if you ask me..
Old Jun 27, 2008 | 06:42 PM
any chance of a summit part number?
Old Jun 27, 2008 | 06:55 PM
hashtagBMW
Looks like Caspers doesnt have a 93-94.
Here is the 95+ for the vented coversion.
http://store.summitracing.com/partde...5&autoview=sku
Old Jun 27, 2008 | 07:01 PM
the only problem with that, Is I already have a non-vented opti, and the car is apart, and ready to install, Brilliant me didnt think far enough ahead...
Old Jun 27, 2008 | 07:26 PM
96capricemgr's Avatar
The complete MSD opti is NOT living up to the hype.
Up side though is an MSD cap and rotor kit for your 93 will be enough to convert to vented. THey added vents to the new cap and rotor so no other changes are needed to the engine. Just have to run the vacuum lines to the manifold and intake plumbing.
Old Jun 27, 2008 | 08:40 PM
How bout a gm part number for the opti harness?
Im looking all over, and cant seem to find one for the non-vented version..
Old Jun 27, 2008 | 08:49 PM
Contact someone like Casper's and ask. Just because it is not online does not mean they can't easily make one.
Old Jun 28, 2008 | 09:19 PM
1badzee's Avatar
+1.. i did the MSD cap+rotor kit about 6,000 miles ago and no problems so far. very happy with it.
Old Jun 29, 2008 | 07:33 AM
93z28_6spd's Avatar
AC Delco for me.. heard to many people had issues with MSD stuff to soon..just my 2 cents
Old Jun 29, 2008 | 11:19 AM
Many people have issues with the MSD opti, not the cap and rotor on a stock base, only problem you can have there is not tightening the rotor screws enough and having it fall off.
Old Jun 29, 2008 | 11:53 AM
Toronto_LT1's Avatar
MSD cap & rotor on the stock base here...runs like a charm.
Old Jul 1, 2008 | 04:38 PM
Ok, well it seems like no one sells a complete harness. But, A friend of mine has a complete weather-pack/ metra-pack kit. So Im just going to make my own. I just need to know if each of the pins stays inline with the pins in the harness that hooks into the rest of the system.
Old Jul 1, 2008 | 06:28 PM
Captainofiron's Avatar
I have an MSD opti, I have run it for about 10,000 miles, ZERO problems, about 80% of the complaints I have heard were from people who installed the seal incorrectly which led to a clearance issue with the rotor.
I have only heard of like a handful of people actually having a problem with the optical portion of the MSD unit.
I did a write up on it not to long ago, its a sticky in the LT1 section of www.ls1lt1.com, if you want to take a look
Old Jul 1, 2008 | 06:31 PM
ive got no clearance issue on my msd opti, Looks brand new inside, It just doesnt work...
Old Jul 1, 2008 | 06:35 PM
946spdz's Avatar
i got my harness from efi connection, i just googled it and it was really nice for 40 bucks
