Nitrous LT1's come in!!
Old Jun 29, 2008 | 04:10 PM
Bad_tx_Z28's Avatar
Default Nitrous LT1's come in!!
Hey guys...im looking into throwing a little juice into the onle Z...i have done some research but i wanted the opinion of some actual users. What brand you have, your mods, and how well you like the system. I appreciate guys!
Old Jun 29, 2008 | 04:18 PM
LS1Silverado05's Avatar
Probably gonna just get told to search... But I too would like some guys from the LT1 world to respond. I think a lil spray is in my future as well.
Old Jun 29, 2008 | 04:31 PM
Bad_tx_Z28's Avatar
i searched plenty...i just wanted to get some current LT1 owners input...
Old Jun 29, 2008 | 04:49 PM
WH97Z's Avatar
I would say go with and NX kit. Thats what im running. I have a bigger fuel pump, bottle warmer, nitrous pressure gauge, and a tune. I would use NGK TR-6 Plugs and gap them at .036 if i were you. You might also want to upgrade your ignition.
Old Jun 29, 2008 | 05:03 PM
Bad_tx_Z28's Avatar
what are your engine mods?
Old Jun 29, 2008 | 05:04 PM
rdlt1's Avatar
I have a Zex 75-125 set-up. I haven't done much to my car, free mods, cai, 3:73, PCM4less tune, NGK tr-6 plugs M/T drag radials, bolt on UMI subframes. 1.70 60 ft. 7.92 @85.52 in the 1/8 on 100 shot. Oh yea the motor has 156K on it and it is all stock.
Old Jun 29, 2008 | 05:16 PM
Bad_tx_Z28's Avatar
i have always heard good things about Zex kits...how often do you spray?
Old Jun 29, 2008 | 05:28 PM
rdlt1's Avatar
About once a week when I go to the track, I will make 5 or 6 runs. Yea the Zex system takes some of the worries out of using the nos since it will cut it off if it thinks something is wrong. Here is a vid of me on a 100 shot run before the subframes, they made a big differnce.
www.youtube.com/watch?v=4hg35b74LXc
Old Jun 29, 2008 | 05:51 PM
Bad_tx_Z28's Avatar
not bad...dont the window switches kinda do the same things for other brands of nitrous?
Old Jun 29, 2008 | 06:06 PM
rdlt1's Avatar
I could be wrong but I think the window switchs just let you set where you want it to come on at. The Zex comes on at wot, just like most others do, but if it detects knock it will stop the nos. That's the way I understand it to work.
Old Jun 29, 2008 | 06:29 PM
officermartinez's Avatar
I have the Cold Fusion 200HP wet kit: http://www.nitrousdirect.com/lt1.html
I went with a 20 lb bottle (10 lb was standard of course), upgraded to a MSD Optispark replacement, MSD wires and NGK plugs.. I am about to sell off my unsightly bottle warmer in lieu of a billet mount with the heater built in. Of course, this is on a fresh rebuild with new internals, etc..
Old Jun 29, 2008 | 07:06 PM
Speed Density's Avatar
hashtagBMW
Nitroust Outlet LT1 plate!
http://www.nitrousoutlet.com/catalog...roduct_id=3043
Nuff said!
Old Jun 29, 2008 | 07:28 PM
faust's Avatar
nitro dave's wet kit, bmn windowswitch ,air/fuel cut off, msd digital6. 150 shot, 6 times a year on my 385 lt1
Old Jun 29, 2008 | 07:30 PM
Blackbirdws6's Avatar
I've been happy with my TNT F1 kit that's been on my car for years. Haven't had any issues to speak of (knock on wood). There are plenty of good kits out there so hit up the nitrous forum for some good info.
-Brian
Old Jun 29, 2008 | 08:07 PM
96lt1m6's Avatar
NX/cold fusion/nos put together kit 150 shot.......
Old Jun 29, 2008 | 08:42 PM
stevema10631's Avatar
i run a NX 75 shot car loves it/i love it lol, just havent ordered the new jets to go larger yet
Old Jun 29, 2008 | 08:48 PM
Bad_tx_Z28's Avatar
wow, thanks for all of the replies...they have been very helpful! keep em coming!!
Old Jun 29, 2008 | 10:18 PM
porksoda's Avatar
I use all Harris Speed Works stuff for my setup, but my window switch is from Nitrous Outlet. I would recommend HSW all day everyday! They answered my countless questions through PM's and phone calls without hesitation. I'm sure I asked the same questions over and over again and never once did I get the feeling from them that they were tired of my constant nagging. LOL That being said I like the Nitrous Outlet plate but I couldn't vouch the extra $200 just for the plate system since I don't plan to spray over 150 ever.
Old Jun 29, 2008 | 11:02 PM
69gto96z's Avatar
I also have the Harris Speed Works kit. Not a bad kit, im using the Mallory 685 ignition box. Also have the HSW bottle warmer, and their FPSS. Sprayed a 150 shot on a stock bottom end LT1 with 140k on it. Used about a bottle a week for about 6 months straight. I also had the racetronix fuel pump kit. Never had a problem! Good luck!
Old Jun 30, 2008 | 12:25 AM
WH97Z's Avatar
I am running 150 shot on bone stock motor. Have a few bolt ons such as jet hot Lt's, custom y pipe, dynomax cat back. Plus in running spohn sfc's, LT4 KM, and drag radials.
