hot cam question
Old Jun 30, 2008 | 12:03 AM
bad99transam's Avatar
Default hot cam question
do you have to up grade to the hevy duty timming set that they recommend, witch would include a different timming cover and opti. i have a 94 and its telling me to upgrade to the 95 comonents.
Old Jun 30, 2008 | 12:10 AM
porksoda's Avatar
No you do not need it but it is a good idea to replace the timing chain while you are there with a GM replacement. You do not need to convert over to the 95+ stuff. Just make sure the dowel pin on the hotcam is the same size as the dowel pin of the stock cam you pull out.
Old Jun 30, 2008 | 12:12 AM
ok thanks i am going to replace the timming set i just didnt want to get in to a new cover and then replaceing my msd opti to a 95 version.
Old Jun 30, 2008 | 12:15 AM
porksoda's Avatar
I feel ya, $515 is not cheap!
Old Jun 30, 2008 | 12:18 AM
lol not at all i see you did the ls1 drive shaft swap did you have a problums hitting your excaust. when i went to do the swap i had counter waits hitting every ware?
Old Jun 30, 2008 | 12:27 AM
porksoda's Avatar
No problems here at all, went in like butter.
Old Jun 30, 2008 | 12:40 AM
how big is your driveshaft mine is out of my 99 trans am m6. its a empire driveshaft i think it is a 3 or 3 and half inch
Old Jun 30, 2008 | 12:52 AM
porksoda's Avatar
Stock LS1 is 3" and it fit perfect. It doesn't hit the exhaust, tunnel, or torque arm. Where is yours hitting?
Old Jun 30, 2008 | 12:59 AM
mine is hitting at the back of the drive shaft on the excaust were the pinion meets the driveshaft and another counter wait hafe way up the exaust i tryed to beat the excaust alittle but it realy didnt help.
Old Jun 30, 2008 | 06:14 AM
SnakeOiler's Avatar
I thought the '94s had a spline shaft, not a dowel pin. Am I missing something here?
Old Jun 30, 2008 | 08:26 AM
bobdec's Avatar
You are correct. The LT4 Hot Cam ships with the longer dowel pin used to drive the '96+ (vented) Optis. The pin needs to be ground down (shortened) when installing in '94-95.
Old Jun 30, 2008 | 08:27 AM
fergymoto's Avatar
They still have a dowel pin for the timing gear. If it is too long it will rub the timing cover around the shaft seal.
Old Jun 30, 2008 | 09:01 AM
ScreaminRedZ's Avatar
registered user
Yeah, just grind the pin down. It'll be fine.
Old Jun 30, 2008 | 12:24 PM
fergymoto's Avatar
You don't even have to grind it. You can just knock it into the cam a little further usually.
Old Jun 30, 2008 | 03:16 PM
thanks everyone so my msd opti will be fine as well?
