Wanting To Run Nitrous On Hyper Slugs
Old Jul 5, 2008 | 11:48 PM
1sicss's Avatar
Default Wanting To Run Nitrous On Hyper Slugs
I've Been Wanting Run Nitrous But I Only Have Kieth Blacks Hyperuetectics Or However It's Spelled. My Question Is Can I Run Nitrous On These And What Size Shot Can I Run. Also What All Do I Need To Properly Run Nitrous. I Currently Have 30#svo Injectors,h/c/i,with All The Complimenting Mods. My Car Is 97 Ss Camaro Lt1 355 With Stock Internals With Kb Slugs.
Old Jul 6, 2008 | 05:00 AM
96lt1m6's Avatar
i run 100-150 on the gm hyperslugs,a few people have run more(175-200) but i feel it's a fine line of disaster especially with stock fuel pump........
be safe not sorry!
255 lph
30+ lb inj(stocks will work fine but they are old now)
hotwire kit(fuel pump)
msd digital 6
ngk tr5 or tr6 gapped @ 35
make a pass then let the motor cool down then pull a few plugs especially #8 read them carefully.....
Old Jul 6, 2008 | 10:45 AM
lt170chevelle's Avatar
i had a 125 on mine for well over a year with no problems.i was all stock with bolt.just run tr6 plugs with a .035 gap, always run 93 or better gas when squeezing and enjoy.but be prepared down the road to have tranny or rearend failures...bound to happen with power adders.one thing that is a wise investment no matter how much nitrous you are running is a progressive controller..it will do wonders on not breaking stuff ..
Old Jul 6, 2008 | 12:05 PM
camar0corey's Avatar
Wideband, don't go lean and you should do alright.
Old Jul 6, 2008 | 03:28 PM
indirocz28's Avatar
a couple years ago, I was running a walbro 315lph fuel pump, 50psi fuel pressure, 26lb injectors, Gm hyper pistons and a 160rwhp wet shot. Made the car nearly completely retarted to drive, even on slicks would spin it sideways at the drag strip..- so i took it all out haha.. but anyways- just dont do anything completely stupid with it, and make sure it doesnt go lean.. Start with like a 100hp shot, -i went from a 100hp shot to like almost 200- made 162rwhp... and i went through 3 10lb bottles on that... Now the car is completly N/A and runs healthy..
