Fuel pressure Regulator??
Old Jul 8, 2008 | 04:46 AM
reaper97's Avatar
Default Fuel pressure Regulator??
Im in the process of in stalling a cam and need to know if i needed a fuel pressure regulator here are the mods ill be doing...
Gm-847 cam, 1.6 rockers, springs, 32lb injectors.. and etc items need for the swap..Thanx
Old Jul 8, 2008 | 06:51 AM
DAVE00's Avatar
The stock one will work just fine, unless you are having issues with it? I am running a 383 and the stock regulator works great for me as it is adjustable with an allen key/wrench. Just my 2 cents - save your money unless you really want one.
Old Jul 8, 2008 | 08:49 AM
96slow6's Avatar
The stock regulator is not adjustable. If you get the SLP convertion for the stock base then it is. I would say you will be fine with the stocker for now, as long as you dont start running into supply issues.
Old Jul 8, 2008 | 08:45 PM
reaper97's Avatar
Ok thanx just wanted to make sure.. wanted to everything right the first time...
Old Jul 9, 2008 | 07:12 AM
DAVE00's Avatar
Oh, my bad you're right. I forgot we did the SLP conversion when we installed the 383 9 years ago. It's been way too long to remember these things.
Old Jul 10, 2008 | 05:22 PM
96slow6's Avatar
No worries. I have the same thing.
