too big a cam for stock heads?
the car right now as it sits has a slp cai, asp UD pullies, a tune and a deleted muffler. (and of coarse all the supporting valve train components for the cam) i know i need long tubes believe me they are next on the list but they should be in within the next month seeing as my birthday is next month early.
i was also thinking that when i get the long tubes to get my intake and heads port matched by a local shop to see if my cam can really benefit from the extra breathing.
obviously im not an expert and am looking for some decent advice thanks!
, those numbers are at .006" and at .050 is it 212 and 224. but per your thread it says that the cc503 is one of the biggest cams to run on stock heads and this cam isnt too much smaller is it? iirc the cc503 is .537 and .544 and mine is what .530 and .540, i always thought the lift numbers were what made a cam "big" but please correct me if im wrong. The Best V8 Stories One Small Block at Time
For reliability sake you want to keep stock shortblocks down to say 6500 or less, meaning peak power 6200 or lower. That is what should limit cam selection. Yes guys go 230+ degrees intake on "stock shortblocks" but that is risky due to rpm, some make it work but rebuilding "stock shortblocks". Some of them just don't rev high enough to make it really work, in which case they would have been better off with smaller.
for .006" number that does not look like a big cam, though the .050 numbers would be nice. The 113lsa would make it a good emisions cam but otherwise is reason enough to skip it.
I ran a zz4 cam for awhile which was 208/221 .474/.510 112 when I had cats on the car it was so mellow guys who knew it was there said it sounded stock. If you are prepared or flat out want a little bit of a noticable cam then you need to look at something with maybe a little more duration and depending on emissions testing maybe a tighter LSA.
but good to hear i was just reading thru another thread and noticed how similiar my cam is to the Crane 227 and other smaller cams with higher lift.
i really just need to get some long tubes on this baby and a decent stall converter.
