low resolution opti code
Old Jul 8, 2008 | 08:18 PM
ElkySS's Avatar
Default low resolution opti code
will this code pop up if the splines on the opti are put on one or two off?
Old Jul 8, 2008 | 08:37 PM
JasonC's Avatar
The splines should only go one way, it is keyed so that it can go on a certain way and thats it.
Old Jul 8, 2008 | 08:44 PM
ElkySS's Avatar
it is possible to put it on a spine or 2 off. i did it the first time. im just trying to find out if my old opti is good or not
Old Jul 8, 2008 | 08:50 PM
Jonez_z's Avatar
I got it off a tooth before and it cost me a rebuild. Burnt a hole in a piston. Dont know if it would give you that code or not, but you need to make certain that it is lined up the way it was intended.
Old Jul 8, 2008 | 09:52 PM
JasonC's Avatar
Mine would only go one way when I did mine not long ago.
Old Jul 8, 2008 | 10:23 PM
ElkySS's Avatar
i just need to know if that code will come up
