Computer issue
Old Jul 9, 2008 | 08:51 AM
cgroh89's Avatar
Default Computer issue
Well after months of my car not running right . between the clutch and opti
I now have brand new msd wires and the tr 55's that are now fouled but the car has been running like it is out of time. We tore it back down and everything is right.
In open loop it will sorta run smooth and rich like crazy but there is no vaccum. Tap the throttle miss. Snap it to wot and black smoke.
My spark advance is 20-25 degrees
If I command it to closed loop my short term fuel trim drops from 128 to 1-10 and miss's like crazy.
and I have a Quadra Driver Fault 1 / Fail < thats what we never saw/noticed before
There are no codes . The opti is new I need my car back Anymore ideas?
Old Jul 9, 2008 | 12:14 PM
MEAN LT1's Avatar
are you still running the stock 24lb injectors?
Old Jul 9, 2008 | 12:51 PM
cgroh89's Avatar
Yes I am ( to the best of my knowledge they were not changed prior to me owning it ) . Though before the opti went out it ran fine. As well I dont know if a computer can loose its tune or something either. or maybe it was a computer issue that caused the opti to go bad
I have a cam with the specs around a hot cam as well.
Old Jul 9, 2008 | 01:12 PM
MEAN LT1's Avatar
Well....tunes dont go bad nor can you loose them. So when the car goes into closed loope both banks drop to like 108-110?
Old Jul 9, 2008 | 02:23 PM
cgroh89's Avatar
No both banks drop to like 1-10 no hundreds I have never seen that before. Plus I had one error which was the quadra driver 1 fault. So I dont know if that can throw timing off or not because it runs like it is out of time
Old Jul 11, 2008 | 08:52 AM
cgroh89's Avatar
I went back over it on the tech 2 last night and it is a QDM 1 Fault.
i also through in my extra computer and it ran worse so I geuss the tune is still programmed in it
Old Jul 11, 2008 | 01:30 PM
infinitebird's Avatar
dirty or bad maf maybe? intake/exhaust leak?
Since it affects open and closed loop it has to be something common to both.
