low voltage
Old Jul 9, 2008 | 11:04 PM
383z's Avatar
Default low voltage
I'm new and I need some help. I have a bad low voltage problem. In park and neutral the the car has 12 volts., around 11 volt. in drive, and 10 volt. when its in drive and the a/c is on. If I'm driving it and I come to a stop with the a/c on, the volts. drop even more and the car will die if i don't throw it in neutral. I've checked....
  • the battery and put two diffrent ones in the car and the volt. didn't chang
  • changed the alternater 3 times . Its a 140 amp now and it does charge. Its never killed my optima
  • no underdrive pully
  • volt. reading at the battery is the same as the gauge in the car
  • checked all visible grounds
  • and it doesn't have a stereo
I've had this problem since the engine was rebuilt. Can someone post some pictures of all the grounds or describe them with detail where all of them are.I might be missing one and not even know it. I would like to check this off the list before I up grade all the old wires and/or take the car to someone and have the little red wire on the back of the alternator to the juction box redone , which will cost me. If any body would like to put there two cents in on how to fix this problem I would love to hear it.
Old Jul 10, 2008 | 07:39 AM
stfuad's Avatar
There is a ground on the passanger side engine mount to the block. Another one from the ICM to the fender. One from the Battery to the fender... and... that's it? I forget.
Check the exciter wire from the alt to the pcm, and the battery to alt power wire.
Old Jul 10, 2008 | 03:42 PM
bobdec's Avatar
What year and model are we looking at here ? Wild guess.. is your belt tight (tensioner OK) ? Any squeals with air on ?
Old Jul 10, 2008 | 07:07 PM
383z's Avatar
Oh yea, Its a 1993 Z28 and its a speed density car. Yes, the belt is tight because it was a pain to put it back on when I just got done replaced the alternator, and no there aren't any squeals when the air is on.
Old Jul 10, 2008 | 10:32 PM
sweet-94z28's Avatar
My car has been doing the same thing. I think its the voltage regulator in the alternator.
Old Jul 10, 2008 | 11:37 PM
FlamingChicken's Avatar
usually a toasted regulator will send your charge level through the roof when you are driving though. i know when mine went out it would reach 18v! when you checked your grounds, did you check the actual ground point? paint or rust will definitely create a poor ground issue.
Old Jul 11, 2008 | 05:16 PM
383z's Avatar
Yes, I checked for rust and if the grounds were on paint, and wouldn't a new alternator rule out the voltage regulator?This is a pain the a**
