quick coolant question
also i was always told when you drain something like the coolant or oil it is better to do it when its warmer because when its warmer more of the gunk will come out, when its cool the gunk settles and hardens. but that just might be me blowing steam but it always sounded logical to me. have they still been having those thursday meets over on northern?
I personally run the Pro-Blend Coolant and my car did run a good 10 degrees cooler than it did with the Green stuff
I get it at work for like 15 bucks but I know its 30 at o Reilly's since I had to drain and re fill my block once and is pissed me off that I just ran over to that store and its twice as much
EDIT: Or you can get a manual fan switch.
Though on my thirdgen I know I had put in a 160 and the loop status wouldnt change because it never fully warmed up I dont know if this is as much of an issue on the lt1s though I would let is hit closed loop and then turn them on
Fan settings are independent of the thermostat.
