Jegs Damper
Old Jul 12, 2008 | 01:26 AM
RallyBoy's Avatar
Default Jegs Damper
Has anyone used the Jegs damper for the LT1 engines? I need a damper for my stroker and I considered the Jegs brand because it seems that it is a quality yet inexpensive piece. Professional Products also makes an inexpensive damper for LT1's that seems like a winner. Opinions please.
Old Jul 13, 2008 | 07:41 PM
RallyBoy's Avatar
Anyone??
Old Jul 14, 2008 | 03:03 AM
ElkySS's Avatar
id also like to know this, so if anyone has used these chime in
Old Jul 14, 2008 | 03:06 AM
connexion2005's Avatar
Out of curiousity whats wrong with your stock damper? It's neutral balanced which means it will still work for an internally balanced assembly. Fyi I'm running the stocker with my internally balanced assembly and zero balancing the flywheel so both front and rear will be neutral...
Old Jul 14, 2008 | 03:08 AM
TwoFast4Lv's Avatar
They look like they are made by PowerBond. I almost got one for the wifes car
BTW Nothing wrong with it unless you need to be NHRA legal
Old Jul 14, 2008 | 02:36 PM
RallyBoy's Avatar
My stock damper is old and the rubber is begining to crack. I figured that it would be better to go aftermarket.
