P1351 Code! 96 Camaro Z28
Here is what the car does: (sometimes)
The car will fire up fine but you let it set for about 3 to 4 minutes idling and it will die. It will not start right after it dies, you will have to wait about 4 minutes to start it again. However, if I get in it and take off with it down the road it will run fine. It you keep your foot in it. It only died one time when was driving it. It became real sluggish and died. I had to wait again to start it, but after that I made it home. Which was about 25 miles from my house. The car has only done this type of thing 5 times while idling so far. Have not tried it since. The car runs fine when I am driving. Not running sluggish or backfiring. I had the car put on a scanner right after this happen the last time. It showed up this code and said that Bank 1 sensor 1 and Bank 2 sensor 1 had a slow response. So I let the car idle and die while having the scanner on. Then it only showed the P1351 code not the others. However this code has been on my car for awhile now before even acting up. It has been on my car ever since I got my ECM back from Madz28 tuner. I tried to delete it but cant. I just need to know what the do about this code! Need help. Please!
These are some things that has been replace within the past year:
optispark (MSD cap and rotor) the bottom piece came from Autozone
NGK plugs and MSD wires
coil pack
ICM sensor
MAP sensor
water pump
fuel pressure regulator
Granatelli fuel pump
fuel filter about 1 month ago
The AIR and EGR has been deleted too!
Just dont know what to do. Any advice will be awesome. Thanks!
This is what that code read for me...
Not sure if I can help but that is a more clear reading of P1351
