LT1 to LS1 front end conversion
Old Jul 18, 2008 | 11:02 AM
scorpion_z28's Avatar
Guys come on this is not a poll about lt1 or ls1 front end.please try to help if you can.
Old Jul 19, 2008 | 05:45 AM
SnakeOiler's Avatar
Originally Posted by scorpion_z28
Some one please help me with those brackets
You should be able to get them from the dealer or a salvage yard. One is the headlight bracket, the other two are fender brackets. If you want the actual names, call up your local parts dept and ask them to look them up.
Old Jul 19, 2008 | 10:28 AM
I called up a dealer today & he said i need 12 Brackets (6 for each side),im not sure i need all of those according to the website i saw they are only 3 for each side.Thats why i want to know the exact names of the ones i need to do the swap.
Thanx anyways
Old Jul 19, 2008 | 10:36 AM
Kmaroman's Avatar
just a really cool thought sticker's that say LT-X or maybe LT-1X
Old Jul 19, 2008 | 11:47 AM
TwoFast4Lv's Avatar
Hell I would dump a LS1 non SS nose for a LT1 nose in a hot minute! You get the best performance and the best looks all at once!
Old Aug 5, 2008 | 01:22 PM
CAMJAG's Avatar
I just picked up a 95 LT1 Vert. I want to do the same thing. I have most of the parts off my other car and another I striped. I have the hood, all the lights, and one fender. Just need to pick up the bumper, one fender, and the brackets.
Old Aug 6, 2008 | 07:23 AM
SnakeOiler's Avatar
Thanx anyways
Take your *** down to the dealer and look at the pictures yourself. From what I understand there are only 3 fender brackets per side. You should check out the pictures to see what they are telling you and you should be able to pick out the correct ones you need.
Old Aug 6, 2008 | 05:49 PM
ORedRoc4's Avatar
Go to a junkyard, jeez... itll make life alot easier and cheaper...
-justin
Old Aug 6, 2008 | 09:42 PM
yogibear19's Avatar
go on ebay and do a search for 98-02 chevy camaro bracket and it will pull up all the brackets that u need.
Old Aug 6, 2008 | 11:41 PM
CAMJAG's Avatar
Im pretty sure its the two brackets on each side of the fender (that makes 4) then the 2 headlight brackets (that makes 6)
Old Aug 7, 2008 | 08:24 AM
Bad93TA's Avatar
this link might help some also:
http://www.lt1engine.com/tech/93-97-...nd-conversion/
