Difference in LT1s?
LT1 out of a 1996 Caprice
LT1 out of a 1995 Impala
LT1 out of a 1995 Camaro
LT1 out of a 1995 Trans-am (says its aluminum heads)
Internally is there a difference? I am planning on running a 6spd, cam and supporting valve train parts, and thats it.
The Camaro and TA motors are the same as eachother, both have aluminum heads, not a gain over iron in stock form but more desirable for porting.
All 4 have the same block and rotating assembly, all the 95s have the same pcm.
OBD2 hubs were the shortest, OBD1 hubs the longest and Caprice/Impala hubs were inbetween.
knowing this comes in handy when using a double roller timing chain set
Engines are all quite similar, just little stuff changed.
