high rpm miss
Old Jul 20, 2008 | 09:55 PM
ElkySS's Avatar
Default high rpm miss
iv got a miss above 5k. new plugs, wires, cap, rotor, msd coil, known good spark module. the only two things i can think of are either opti or the new plugs need to be gapped closer. fyi the plugs are TR55s and the wires are cheapo o'rielly brand. cap and rotor are acdelco
Old Jul 20, 2008 | 09:59 PM
TwoFast4Lv's Avatar
what are the O2s telling you?
Old Jul 20, 2008 | 10:10 PM
ElkySS's Avatar
i dont have a scanner, i have a big exhaust leak so the readings would be off anyway (working on fixing that) but they arent throwing any codes if thats what you mean.
Old Jul 20, 2008 | 10:14 PM
ElkySS's Avatar
it still needs to be retuned i know that. theres only a basic tune on it right now. idk if he calibrated the knock sensor for headers and roller rockers, idk what he did with the rev limiter, idk if its tuned for a 160 thermo, and i do know the speedometer is off because i never told him i have 4.10s. also i do rev the motor a little higher. 6300-6400 with the new cam, springs, rr, guide plates, ls7 lifters,
Old Jul 21, 2008 | 03:15 AM
BIG_T's Avatar
im having the same issue with new everything including a opti
Old Jul 21, 2008 | 07:57 AM
sw07gt's Avatar
I have the same problem with mine.
Old Jul 21, 2008 | 08:21 AM
TwoFast4Lv's Avatar
I had the same issue again unit I replaced our little friend now I can rev to 7,200 again.
Take care of the basics and see what the numbers are then
Old Jul 21, 2008 | 10:17 AM
ElkySS's Avatar
is there any truth to having it gap the plugs narrower in order to rev higher?
Old Jul 21, 2008 | 04:53 PM
ElkySS's Avatar
bump..
Old Jul 23, 2008 | 11:31 PM
ElkySS's Avatar
iv been told that i need a colder plug with just a cam and 30# injectors. anyone have to run TR-6s instead of tr55s?
Old Jul 24, 2008 | 11:41 PM
ElkySS's Avatar
ok well i tried putting in TR-6s gapped to 0.050. i think it runs a little better until it hits about 5k and then it goes right back to its same old miss. im thinkin opti, but it was working fine before the cam install. i would rev it to 6k and it ran fine then. im just trying to get the little things out of the way before i try the big thing. not sure what valve float feels like. been told this could be it. i might try resetting my valve lash. any more ideas on what it could be?
