Ls1 lid and airbox on lt1
Old Jul 21, 2008 | 11:28 PM
AAK z28's Avatar
Default Ls1 lid and airbox on lt1
does puttin the ls1 lid on a lt1 mak any difference? whats better a k&n cai or a ls1 lid and air box with a k&n filter
Old Jul 22, 2008 | 12:38 AM
96lt1m6's Avatar
This is one of the most debated questions ever..if you do a search on it,it will give you insight....search "the merv"
personally i feel it gives a bit more MPH 1-3 from my own test.
Old Jul 22, 2008 | 05:58 AM
qwk93ta's Avatar
I did it to my LT1, I thought it was a good mod, but I can't tell you if it made the car any faster.....it does clean up the engine bay. You will need a SS, WS6 or similar hood to make it work.
http://s229.photobucket.com/albums/e...1Image0034.jpg
Old Jul 22, 2008 | 08:21 AM
tspence45's Avatar
^^^^You don't need a different hood for it to work. But, there will be quite a bit of cutting and you have to lay the radiator back for it to work on the stock Z28 hood.
https://ls1tech.com/forums/showthrea...ht=ls1+lt1+lid
Old Jul 22, 2008 | 09:07 AM
ScreaminRedZ's Avatar
registered user
I don't have any personal experience with the swap, but looking at the design of each, I don't know how it couldn't help. There's a reason GM went with that design.
Old Jul 22, 2008 | 09:30 AM
96lt1m6's Avatar
it helps because you are actually getting air from the front similar to the ram air design rather than to extract air from a fender well...
Old Jul 22, 2008 | 09:33 AM
ss.slp.ls1's Avatar
Maybe try to find a LT1 SS hood and use the SLP ram air.
Old Jul 25, 2008 | 11:09 AM
qwk93ta's Avatar
You do if you want to use stock equipment like I did.
Old Jul 25, 2008 | 11:50 AM
slick1851's Avatar
Somone posted info awhile on this and it made power
To me id do this over any cold air out there, and take out your fogs or rig it up like the LS1 guys do to duct more air into the lid.....
Search(Free ramair more) in the LS1 section
Somone also did like 4inch PVC intake that helped, the more air and the better air flow the better.
Old Jul 25, 2008 | 04:11 PM
jedimaster71472's Avatar
Cool idea.
Old Jul 25, 2008 | 05:26 PM
hyperzone's Avatar
simply swapping to an SS hood will do nothing to help clearance this mod. The spot where you'll need more room is more toward the nose and the SS hood isn't any higher at that spot than the stock Z28 hood. The Ultra Z hood will work. Maybe certain cowl hoods. If your not up for a hood swap then you'll have to do some rearranging and probably some cutting of the radiator support. As stated above, do a search on "LS1 lid LT1" and you'll find a lot of talk on this one.
Old Jul 25, 2008 | 06:19 PM
StealthFormula's Avatar
Unsure of any power differences but an LS1 lid would look alot nicer under the hood than your traditional CAI plus it would be different.
Old Jul 26, 2008 | 12:20 PM
bricez28's Avatar
ive been wanting to do it also i just need to know what i need to do to make it go with the stock parts. under the hood not the hood itself ill take care of that
Old Jul 26, 2008 | 12:40 PM
97Z28LT1's Avatar
This will probably give you an idea of what you're up against.
http://www.lt1engine.com/tech/ls1-li...k-camaro-hood/
Not a bad tech-aid, and its for a Camaro. I don't know if the Pontiacs are going to be the same or not. Lots of pictures, but it doesn't really have "step by step" instructions. Reguardless, it looks easy enough to figure out.
Old Jul 26, 2008 | 02:05 PM
the_merv's Avatar
Veteran: Air Force
Thanks bro..
Here are some pics..
Then I got bored and swapped out the Engine .. but it still works the same..
Old Jul 26, 2008 | 08:02 PM
Bad_tx_Z28's Avatar
^^^ when you get a chance merv, i wanna hear a idle clip of that hoss...
To the O.P. i think this is a benifical mod...i like the way it looks as well
Old Jul 26, 2008 | 10:37 PM
AChotrod's Avatar
Do you think that set up is better than the Pontiac LT1 WS6 Factory ram air?. And would the LS1 free ram air mod, the one where you cut out the bottom of the airbox work on a WS6 LT1?
Old Jul 27, 2008 | 02:26 AM
the_merv's Avatar
Veteran: Air Force
Here ya go..open Cut-out too..
Old Jul 27, 2008 | 08:32 PM
That's why it's attractive to me as well. I wonder if there are clearance issues with a Firebird. I read above that there may be with a Z28. Not sure how it all lines up with the Pontiac.
Old Jul 27, 2008 | 08:42 PM
the_merv's Avatar
Veteran: Air Force
I got mine to work, had to cut very little out from under the Hood. You can tell I had to do a little work on that Cross Brace..
