Is my machine shop right??
If you are indeed just putting everything back together, but using studs vs. bolts, then YES, your machine shop is correct.
Now, having said that, some will say that if you have everything apart and the engine is already at a shop which can align hone it (only taking off 0.0005" or so...) then that is always a good idea...
The $64K question is can that shop hone the mains? If they can, and won't charge you an arm and a leg, then it is just a good idea, as straight is good.
a line hone will make sure the mains for the crank is straight and true which they should be able to do cheap...les than 25 bux
they did STRONGLY suggest to instal the studs,tq to spec and mic the mains,if in doubt hone it out!
