The Cam Is Picked For The 383
Old Jul 25, 2008 | 12:22 PM
th3brandon's Avatar
Default The Cam Is Picked For The 383
well the cam i will be going with is the xfi 292(yes i know its big)...i will be running stock ported heads and intake along with beehave springs and lt4 roller rockers off my other set up and problly some differnet pushrods not sure yet. What do u guys think
Old Jul 25, 2008 | 01:14 PM
ss.slp.ls1's Avatar
I think that cam will work well in a 383. You will def need chromoly hardened push rods. Make sure to check all of your clearances (ptv, rod to block, rod to cam, etc). Good luck.
Old Jul 25, 2008 | 03:53 PM
th3brandon's Avatar
so u guys think chromoly push rods...does anyone have a link on where to buy a good set of these...iam tryin to make a good setup that will hold up for a pretty long time
Old Jul 25, 2008 | 04:23 PM
ss.slp.ls1's Avatar
I would try to find a kit from a sponsor that has the pr's, springs, TI retainers, locks, etc.
Old Jul 25, 2008 | 04:55 PM
slick1851's Avatar
Why the hell do people go to lengths to build custom strokers, then use some off the self crap?
Get a cam cut to your needs, your motor, and your head flow
Stop wasting your time with off the shelf stuff
Old Jul 25, 2008 | 06:09 PM
th3brandon's Avatar
i would get a custom cam but i like the gains i saw from this cam and how other guys r running with it
Old Jul 25, 2008 | 06:42 PM
96capricemgr's Avatar
Well the GMPP rockers wont work with it, the titanium retainers one poster recommended are pretty much a waste given the price and tiny weight reduction. But hell if you are going to go halfassed, don't let us talk sense into you.
Old Jul 25, 2008 | 08:15 PM
ss.slp.ls1's Avatar
I thought that people ran the TI retainers for increased strength for the higher spring rates and seat pressures?
Old Jul 25, 2008 | 08:42 PM
texas94z's Avatar
i always wanted to see somebody use xfi 292 effectively. fergymoto (sp) had one in his lt1 and it sounded awesome. my roommate nutted when he heard it. heres a clip http://www.youtube.com/watch?v=Bh7vQnOEiEU. i believe he said that the 292 was way to ****** big for a 350 and a mild headed 383.
you need a very solid valvetrain and some very good flowing heads to use this cam for a 383. but i would recommend a custom grid also.
Old Jul 25, 2008 | 08:54 PM
ss.slp.ls1's Avatar
Damn, that cam sounds sick! Too bad its not streetable for a 350.
Old Jul 25, 2008 | 09:02 PM
texas94z's Avatar
yeah man its def my fav sounding lt1 ever. hands down.
Old Jul 25, 2008 | 10:35 PM
kinglt-1's Avatar
Sounds alot nastier than it is, just like mine!
Old Jul 26, 2008 | 01:01 AM
th3brandon's Avatar
y wont the roll rockers work....if thats the case then whats a good vt kit i can buy that will hold up for me...iam just tryin to get some good info...and who said anything about halfassing it...thats y iam trying to get help from u guys in the first place
Old Jul 26, 2008 | 01:03 AM
th3brandon's Avatar
dude thats a great vid and man i love the sound of that thing...was that a 350 or 383 btw and do u no any other mods on that thing
Old Jul 26, 2008 | 07:20 AM
When fergymoto tried it he found that at 7000rpm it still had not peaked so he has admitted it was a mistake.
Titanium retainers arfe for weight savings BUT the beehive retainers are so small and light that there is little weight to be saved.
Like I said, the rockers wont work and I think you will be better off if I make you work for that info, maybe uyou will learn how to do meaningful research then and not make bad choices like you have sofar.
Old Jul 26, 2008 | 10:17 AM
slick1851's Avatar
Who gives a **** about sound, if its not making the right power
Old Jul 26, 2008 | 11:02 AM
th3brandon's Avatar
thanks for the help buddy...or yea forgot if its not AI its not good right ???
Old Jul 26, 2008 | 11:48 AM
BALLSS's Avatar
You will need to get a PR measureing tool for $12 to confirm what length PR you need. The cam you picked has high lift and depending on how much your heads are milled and head gasket thickness your PR length to achieve valve train geometry that is correct needs to be confirmed
Comp Pro Mag 1:6 RR would be my pick. Go NSA and use hardened guide plates ISKY makes adjustables which allow perfect allignment. Do not use GM guide plates with hardened PR's.
Trick Flow (or other brand) PR are good. Get .080 wall PR's 5/16" tube. I went with these but you need to confirm length first
http://store.summitracing.com/partde...0&autoview=sku
I would also go with 7/16" RR studs
Set your bee hives up at 1.800" installed height which means your spring pockets need to be machined down. Go with 1/4 turn lash
Old Jul 27, 2008 | 09:44 AM
That's the spirit, when someone tries to stiop you from messing things up attack them. Far as good stuff there is goo stuff besids AI, the Lingenfelter stuff is good. I can think of some guys doing hand porting that do good but most of you are so sucked in my marketing that you buy garbage marketed well.
Have you looked into my comments on the rockers?? You should, ignoring me will break parts.
After you sort out those broken parts and if the engine survives such then you ill find a piece of info Roger here offered is wrong but it will only cost performance, not be fatal like the other major mistake.
Old Jul 27, 2008 | 10:38 AM
fergymoto's Avatar
It is a must that you check piston to valve clearance with that cam due to the long duration. It did not clear on my 350 with stock pistons. It did run good in my buddy's stock headed 383 surprisingly, but there are better choices out there. It still had to be spun to 7,000 even in the 383. For $100 more, go custom. Talk to Bret Bauer or AI like caprice said.
