few questions after pacesetter lt install the install went well...time consuming but we all know that.....both went in from bottom...took off alt, dip stick, and stearing linkage.... at idle and wot the car feels wonderful under slight to moderate load SOMETIMES it feels like its missing or there is a vacuum leak....im thinkink maybe its somethin to do with egr still on but the gas feed line is capped off....maybe sumthin to do with closed loop...wires are all good and so are the plugs....i also have the lt4 km....im about to go take off the egr valve and solenoid...and cap it off....hope this fixes it bc i gotta drive back home tomorrow |
just unplug the egr solenoid and make sure it has a good fuse. i couldn't reach my hands back there to take out the egr crap. same for the air pump, which I ripped out though. |
well i got it off and blocked...took the vacuum lines and pulled an end off...then squirted some rtv sealant into on.....made my own vacuum plug for the nipple on the intake....drove it around...no more problems...just the check engine light on for the egr i assume |
© 2024 MH Sub I, LLC dba Internet Brands
