whats everybody think of this cam
Old Aug 2, 2008 | 04:44 PM
robsquikz28's Avatar
Talking whats everybody think of this cam
do you guys think this cam will make lots of power with all the other added bolt ons already on the car. r there better cams or comparable cams to this
how would nitrous are even a blower setup respond to this just looking for comments and thoughts responses.
CAM SPECS -- INT EXH
DUR @ .050: 218 224 LOBE SEP: 112.0
VALVE LIFT: .495 .503
with just 1.5 rockers
Old Aug 3, 2008 | 01:47 AM
bigbadblack93z's Avatar
its small w/ a slight lope. unless its $50, there are tons of better cams out there.
Old Aug 3, 2008 | 02:01 AM
ZFan88's Avatar
small...do some research
Old Aug 3, 2008 | 02:50 AM
94'BLKBRD's Avatar
Not worth the time/money
Old Aug 3, 2008 | 03:10 AM
dre2013's Avatar
waste of $$...on a stock headed stock bottom end car i would run a cc503. when you start opening up the heads and such, a larger cam can be utilized
Old Aug 3, 2008 | 08:24 AM
96capricemgr's Avatar
Not a great choice but at least as good as the HOT cam. Don't listen top those saing it is too small. Remember overcamming is one of the most common and enduring mistakes in hotrodding. The cam I run is fairly close to the 503 and I would call it on the big end of what is prudent on a stock shortblock.
Old Aug 3, 2008 | 08:55 AM
yep now thats what i was thinking some guy asked me if i would like to install this cam on his car now it came with all necessary hardware and a pcm tune with it as well he was telling me with this cam he said they told him he can produce 350+ hp and tq!!!!!
Old Aug 3, 2008 | 09:28 AM
It will make more than 350 flywheel but not rear wheel which is what most guys talk. Just so you understand how to compare numbers.
Old Aug 3, 2008 | 10:17 AM
yea well i knew that but all of u and myself think its a waste of time cam although it comes with everything and a tune built in
