Nitrous Questions
Old Aug 3, 2008 | 01:47 PM
sw07gt's Avatar
Default Nitrous Questions
Whats a good kit? What all do I need to buy? What can I safely run on a stock LT1 motor with intake and full exhaust? Oh and what could cause a miss around 5k and why would it miss in every gear except 1st?
Old Aug 3, 2008 | 02:10 PM
camaro-94-z28's Avatar
and the miss sounds like you need a tune up
Old Aug 3, 2008 | 02:12 PM
sw07gt's Avatar
Yea thats what I was thinking. I was going to hold off on getting it tuned until I get the nitrous kit.
Old Aug 3, 2008 | 02:18 PM
sw07gt's Avatar
Forgot to mention I need a kit that can be taken off in about 6 months and put in a 07 Mustang GT without to much of a hassle.
Old Aug 4, 2008 | 08:50 AM
sw07gt's Avatar
anyone???
Old Aug 4, 2008 | 10:54 AM
LM97Z's Avatar
Get the car miss squared away 1st., make sure you have good fuel pressure/good tune before adding any nitrous, you'll need a window switch also, Nitro Dave has a base line kit for around 360.00, should work fine on both cars.
Old Aug 5, 2008 | 10:14 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
correct....if you are wanting a kit to use an multiple vehicles you will want a single nozzle system.
Our Brand X kits start at $349
Old Aug 5, 2008 | 12:15 PM
OutlawZ's Avatar
High RPM misses on a near stock vehicle like what you're sounding like you're describing could be platinum plugs.... if you're running platinum plugs get rid of em.... No splitfires, v power and stuff like that... Run some TR6's or TR5's and you'll be golden...
but like others said, watch fuel pressure, find a way to pull timing out, DO NOT run hypertech power programmers and leave the timing alone as those things advance timing and you will hurt the motor...
Dave's makes a good kit, nitrous outlet as well... I had good luck with the TNT plate system.....
150 shot chopped off 1.3 seconds and added 14 mph.....
Old Aug 5, 2008 | 12:40 PM
kinglt-1's Avatar
^Agreed
Old Aug 5, 2008 | 12:44 PM
Elliott's94Z's Avatar
Isn't there a Nitrous section for questions like this?????
