LS1 Driveshaft
Old Aug 9, 2008 | 09:59 PM
Cheap Guy's Avatar
Default LS1 Driveshaft
I finally got a LS1 driveshaft for cheap. Anyone do anything special before changing to the LS1 aluminum driveshaft?
Old Aug 9, 2008 | 10:06 PM
qwk93ta's Avatar
Nope.....used one on my 93 T/A for a year or two.
Old Aug 9, 2008 | 10:17 PM
96lt1m6's Avatar
put it in and enjoy!
Old Aug 9, 2008 | 11:52 PM
LSWHO's Avatar
Don't they break easy?
How much power can they free up anyway? .2hp? (me wondering if it's worth it to buy one)
Old Aug 10, 2008 | 12:54 AM
hyperzone's Avatar
I've never heard of it giving you any power. Only heard of it removing vibration, and, that is only if you had some bad vibration from the porly balanced stock steel version. I think weight savings are minimal as well. Although, I guess every pound adds up.
Old Aug 10, 2008 | 01:02 AM
LSWHO's Avatar
I would think less rotational mass would help out though. Also the weight savings.
If I got one free, I'd do it. Otherwise the stock one I have is already pretty damned light.
Old Aug 10, 2008 | 01:23 AM
94LT1Bird's Avatar
mine stock one is a big rust stick....i think ive lost enough of it to where its lighter than the ls1 ds
Old Aug 10, 2008 | 08:26 AM
the_merv's Avatar
Veteran: Air Force
The Aluminum Drive Shaft frees up like 7 horse and 5 torque.. there is a Dyno comparison floating around here somewhere.
It's a direct bolt in. As far as power handling.. some hold out well, some have broken. I got enough power through mine to hit mid 1.5X 60 ft's and blow the 10-bolt up.
When I get the T56 in, I know the Moser 9" is going to hold out, so I'm going to be testing the integrity of that Aluminum Driveshaft..
Old Aug 10, 2008 | 10:00 AM
fergymoto's Avatar
Better get some loops...
Old Aug 10, 2008 | 10:16 AM
Stroked96Bowtie's Avatar
Have lots of track passes with slicks and 3k launches...no problems out of my LS1 DS so far, low 1.6x 60s all day on it.
Ive got one for sale if anyone wants one, shoot me a pm.
Old Aug 10, 2008 | 11:27 AM
Cheap Guy's Avatar
Whoa, at first I thought you were talking about me with my tire-shredding stock 275 hp!!!
What I was looking for is if you guys were replacing the u-joint before putting the thing in.
Old Aug 10, 2008 | 01:04 PM
highflyin's Avatar
I installed a ls1 driveshaft in a 95 firebird yesterday. I replaced the front u joint just because i had to put the front yoke off the steel ds to the new one. The rear u joint felt fine and only had 59K miles on it so i didnt change it. If you have any doubt then just replace them because they are cheap.Around 14 dollars each.
Old Aug 10, 2008 | 01:32 PM
Elliott's94Z's Avatar
Rally the hell out of mine
Old Aug 10, 2008 | 03:16 PM
Storms of War's Avatar
Anyone feel a noticeable difference in power? I've heard they rev quicker with the aluminum driveshaft too
Old Aug 10, 2008 | 03:31 PM
ZexGX's Avatar
I felt a noticable increase in acceleration when I replaced the 1-piece steel DS with a 1-piece aluminum one on my V6... Before, the engine would rev and the car would accelerate, but it still felt heavy despite being quick. After switching the DS it now feels quick. Seems like it takes less effort for the engine to get the power to the road quickly. Cruising RPMs seemed to drop about 50-100 but that could be my imagination... Definitely worth the money spent ($80).
Old Aug 10, 2008 | 03:36 PM
Cheap Guy's Avatar
The u-joints seemed fine so I said what the hell and started to put the DS in when I noticed the cap was missing from the new DS. Fortunately the steel DS caps were the same (according to NAPA and AZ) so I just squirted some lith grease in the caps. My only suggestion is that you use jackstands instead of ramps so you can rotate the shaft to get to the bolts. (duh)
As far as hp, with my butt dyno I'm guessing at least 30 rwhp. The DS is really the only performance difference between the LT1 and the LS1 so I'm ready to go LS1 hunting.
Seriously, I only got the aluminum DS because it was only $75 and I heard it was smoother at "high" speed and I generally cruise at 80 mph. It is a LOT lighter than the steel shaft, but I'm not expecting miracles. Anyone who says it is a performance increase, please show me a link.
Old Aug 10, 2008 | 03:55 PM
the_merv's Avatar
Veteran: Air Force
Hopefully someone has the link for it.. I can't find it.
It is definately smoother, I noticed the difference, it got rid of the vibration at 75-80mph.
Old Aug 10, 2008 | 04:59 PM
CamaroRacing12's Avatar
i got one, and i love it... every pound matters
Old Aug 10, 2008 | 05:19 PM
infinitebird's Avatar
Got rid of highway vibrations for me. Much smoother ride now.
Old Aug 10, 2008 | 05:36 PM
I believe the rule is every pound off of your rotating drivetrain assembly is equal to removing 10lbs of wieght out of the car, same effect....so if the DS was 10lbs lighter (just for examples sake) that would make a diff of 1/10th off of your et. In reality I think its more like a 5-6lbs diff, but not 100%. Ive got a steel and aluminum one in the garage, just dont have a scale to wiegh them. For the cost and ease of install cant beat it.
Also, I replaced the ujoints in mine before it went in...just so I know what Ive got. It was about 30$ for installed ujoints and balanced...well worth the piece of mind.
Ive still got one for sale
