Best fuel pump for my setup
Old Aug 11, 2008 | 11:54 PM
93 black t/a's Avatar
Default Best fuel pump for my setup
So i dont know what fuel pump to run. My setup consists of a 355 with LE2 heads and cam, supporting bolt ons, 36 pound injectors, and a 100 shot. I was looking at the Racetronix pump with the upgraded wiring. What do you guys think?
Old Aug 12, 2008 | 03:24 PM
simple's Avatar
thats a good choice as long as its the 255lph pump.
nitrous a wet or dry shot?
either way i would think that a 255lph pump with the racetronix hotwire kit would be sufficient.
Old Aug 12, 2008 | 03:46 PM
BizZzatch350's Avatar
Moderator
I got the racetronix fuel pump kit from Thunder in my 93, $150.
Old Aug 12, 2008 | 04:49 PM
kinglt-1's Avatar
walbro 255 is the goods!
Old Aug 12, 2008 | 09:14 PM
Its a wet shot. Yeah i'm definitely going 255lph. I guess what i should've asked is the hotwire kit necessary and worth the extra money.
Old Aug 12, 2008 | 11:16 PM
simple's Avatar
IMO, it is a good idea to hotwire the fuel pump!
the racetronix wiring is grade A stuff, high quality.
Caspers electronics also sells a hotwire kit.
constant voltage to the pump is a good thing!! especially under a power adder where the chance is much greater at grenading the motor if you have a fuel problem.
Old Aug 12, 2008 | 11:21 PM
koolaid_kid's Avatar
The "kit" is the pump and the wiring harness, and is more than $150, unless I have missed something. Thunder Racing does show the pump alone for $150.
And yes, it is worth the money. The harness removes any possibility of a voltage/current drop to the pump, allowing it to function at its full capacity at all times. And the pump is custom fit for each year, so no chopping of the fuel bucket is required. All in all, a very worthwhile investment, IMHO. Not a vendor, just a very satisfied user.
Old Aug 12, 2008 | 11:52 PM
97lt1camaro's Avatar
I agree. The instructions that come with the kit are very detailed also.
It was a very easy install. The things that took the longest on my install was waiting for the glue on the bucket to dry, and running the wire under the car haha
Old Aug 13, 2008 | 12:03 AM
Next level's Avatar
just out of curisouty not trying to hijack the thread but what about a 396 with 42LBS and the LE3 package w/o the spray ?
any help ideas would be nice ?
Old Aug 13, 2008 | 12:07 AM
Alright, thanks guys!
Old Aug 13, 2008 | 12:19 AM
simple's Avatar
you would most likely be fine, with a 255lph pump and hotwire.
you should get an adjustable fuel pressure regulator, so you can play around with it when tuning the car.
the hotwiring of the pump IMO, is a good idea for any internally modified EFI car!
Old Aug 13, 2008 | 10:55 AM
Next level's Avatar
I already have a aeromotive (sp) adjustable fuel pressure regulator. Does anyone have a link for the 255Lph Hotwire Pump ?
Old Aug 13, 2008 | 11:40 AM
http://www.racetronix.com/RX-FLT1-FPKG-2.html
Old Aug 13, 2008 | 01:49 PM
Next level's Avatar
Thanks buddy
Old Aug 13, 2008 | 03:08 PM
kinglt-1's Avatar
a 255lph without the hotwire would be sufficient! Although it wouldn't hurt either! I have just a walbro 255lph without the hotwire and I got more fuel than I would ever need for this setup. Oh and thats with 44lb injectors!
