E Brake Woahs!
Old Aug 14, 2008 | 07:08 AM
transamws6_97's Avatar
Default E Brake Woahs!
Okay so earlier this summer my ebrake cable snapped in half so I finally got around to putting a new one in. As soon as I got it in it was working great. Was very tight and only had to pull up about half way to get full holding power. Now that it's been in for a week it now goes all the way up without much force and doesn't hold my car worth a ****. Also it has to be sticking onto my rotor because there is a lot of play near with the handle in the down position and when I'm driving you can feel the e brake holding the car back. I will decelerate between gears, harder to start the car from a stop, and I could smell it cooking on the highway....this car has been nothing but a bitch all summer long (Rob can vouch). So what can I do about this
Old Aug 14, 2008 | 07:33 AM
Jditlfm's Avatar
sounds like the rear calipers sticking. Unless some how you totally messed up the cable install.
Old Aug 14, 2008 | 07:40 AM
nope cable install was fine...exactly like the old one that came out...i really don't k now how you can fubar an e brake cable install lol
Old Aug 14, 2008 | 09:49 AM
RickyMartinZ28's Avatar
Mine is gay too. Loves the dick.
-Rick
Old Aug 14, 2008 | 09:53 AM
Bad_tx_Z28's Avatar
yeah mine snapped last year...didnt feel like replacing it...looked like a PITA, but to the OP i agree, it sounds like a stuck caliper.
Old Aug 14, 2008 | 02:21 PM
Fixxer99TA's Avatar
Haha, sounds like what Ive got going. 2+ years here, and no intention of fixing it
At least I can scare passengers by ripping it up randomly on the highway.... You guys should see the look on some peoples faces
Old Aug 14, 2008 | 03:13 PM
well i'm having a friend come over and we are gonna look at it tonight because it HAS to be fixed because i leave for school in a few days and it's my only car....i will keep this thread updated
Old Aug 14, 2008 | 03:16 PM
Fixxer99TA's Avatar
Yeah post back with the results, Im interested to see how it turns out. And Im with everyone else on the caliper sticking, you already know its dragging so Im sure if you get to the bottom of that you will find your problem with the Ebrake also.
Old Aug 14, 2008 | 05:55 PM
well i got it in the air...while laying under the rotor i had someone pull the e brake and it was very inconsistent. sometimes it wouldnt move at all and sometimes just a lil and then one time they put the handle down and it finally released all the way and finally there was tension on the handle again...no idea why my parking brake is sticking at all
Old Aug 14, 2008 | 06:09 PM
Fixxer99TA's Avatar
How did the other cable break? Was is corroded and snapped or just snapped?
There could still be some rust, junk, debris ect. inside where the cable goes and not allowing free travel.
Old Aug 14, 2008 | 07:06 PM
it was actually the front cable that broke...i have no idea how it broke but it broke right near the e brake handle. After looking at it w/ friends we couldn't really find anything wrong. The rear lines were almost like siezed up it seamed and after moving them around a bit it worked again
Old Aug 15, 2008 | 03:09 PM
halucinator's Avatar
I've had a random problem like this. When I park it. I put my foot on the brake and pump the e-brake handle up and down. Only takes about 3-4 times before it stiffens back up and holds my car good.
Old Aug 16, 2008 | 04:50 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
It could actually be something like a colapsed brake line. I've heard of it happening before.
Old Aug 17, 2008 | 10:23 AM
flyinZ's Avatar
I have yet to have a problem with the actual Ebrake part. The only part I am having trouble with is the Ebrake handle, and the spring-loaded button...HOW the hell do you get that back in the handle and hooked?
Old Aug 17, 2008 | 04:43 PM
OWN3D BY MY PROF!
I can't see pictures here at work because of filters, but I know I took pictures of it in my 93 thread. Click that one in my sig.
Old Aug 17, 2008 | 07:54 PM
the_merv's Avatar
Veteran: Air Force
There is a little set screw that is back there''it's a little allen key screw..real hard to see.
Old Aug 17, 2008 | 11:56 PM
Fixxer99TA's Avatar
Any luck with that E-brake?
