Tranny problem?
Old Aug 15, 2008 | 04:29 PM
grnmonster's Avatar
Default Tranny problem?
So im driving on the freeway and i notice smoke coming out of my rear so i pull over and there is tranny fluid everywhere underneath looks like its coming from the rear of the tranny right next to the torque arm .....my i drove it back home slowly and it was still shifting fine and i have never had any problems with it so what do you guys think its leaking from ....rear main seal maybe ....? please say ,my tranny is not shot i have no money!!!!!
Old Aug 15, 2008 | 04:46 PM
BigZee71's Avatar
Sound like the rear seal may have **** the bed. Get it on jack stands and get under the car and hose everything down with brake cleaner and then see if you can pinpoint the leak.
Old Aug 15, 2008 | 04:51 PM
grnmonster's Avatar
Old Aug 15, 2008 | 05:58 PM
Badazz 97 TA's Avatar
it could be the seal that goes where the driveshaft slides in. there is also a O-ring that goes in between the tailshaft and the trans when the two mate up againts each other. either way there both easy fixes.
slide the driveshaft out. unbolt the 4 bolts that hold the tailshaft on and un bolt the torque arm. you will also need a jack to support the trans since the cross member will have to come out also
Old Aug 15, 2008 | 07:13 PM
nemanracing's Avatar
+1 check your seals josh. im sure jason will help and if im off work i`ll help
Old Aug 15, 2008 | 07:18 PM
grnmonster's Avatar
yea i checked it out its defanately coming from that seal where the driveshaft slides into the tranny ...i gave it a little squezze and tranny fluid came out....
Old Aug 16, 2008 | 10:36 AM
grnmonster's Avatar
bump..
