starter sparked and went dead
Old Aug 16, 2008 | 09:47 PM
BizZzatch350's Avatar
Moderator
Default starter sparked and went dead
Wiring up the nitrous kit we tapped a yellow wire going to a solenoid that has some to do with the starter near the automatic shifter. Ended up not using it, when we tried to start the car the starter sparked then went dead. The starter wont make any noise when you try to crank, how ever I noticed the volt gauge doesn't move, almost like your not doing any thing. Generally when I have had bad starters, the volt gauge would move as you tried to crank, this one wont do that. I dont believe the starter is fried, rather that its not getting any power, any input?
Old Aug 18, 2008 | 07:26 AM
Tony Shepherd's Avatar
That may be the shift interlock solenoid. You may can bypass it to see it that is the culprit. May have fried the solenoid when you wired into it. Also check your fuses.
