94 Z28 overheating....................
This is how I bleed: Fill the radiator with both bleed screws open until the radiator is full and and there is water seeping from the bleed screws. Next I close the bleed screws and
start the engine with the cap off and wait for the crossover tube to stop bubbling.
Then I let the car run (with the cap on tight) until its at the operating temp and then shut it off. Next open the
bleed screws. Each time I do it like this I wont have to open the bleed screws more than twice. Once to bleed, once again to double check. Hope this helps.
Its also very important to bleed the system WITH THE ENGINE OFF.
There you go! I'll bet that is your problem. Easy fix at least.
Ive bleed it a million time just like stated above and it doesnt help.
